Old 02-08-2021, 06:41 PM   #1
jmason
Drives: 18 ZL1 1le
Npp exhaust valve
Does anyone have the pin out of the exhaust valves?
jmason is offline   Reply With Quote
Old 02-08-2021, 07:44 PM   #2
koolkat68
Drives: 2022 Vivid Orange Metallic LT1
Is this what your looking for?
koolkat68 is offline   Reply With Quote
Old 02-08-2021, 09:06 PM   #3
jmason
Drives: 18 ZL1 1le
I’m not sure. Doesn’t look like it’s for the NPP
Old 02-09-2021, 08:27 AM   #4
SomeGeoffGuy
SomeGeoffGuy's Avatar
Drives: 2023 2SS Convertible
The four rectangles along the bottom are the four NPP valve connector pinouts. Two on the left are for the AFM valves, two on the right are for the loudness control.
FYI, If you are just thinking you can put a switch with a hot lead to open and close them, it won't work. You need a specific PWM signal from the controller. You could switch the valves from "working" to "not working" by opening the hot lead, but that is it (so if they were closed when you switched it, they would stay closed, and visa versa).
-Geoff
'16 2SS Convertible - White on white, mag-ride, NPP, nav. Sold!
'23 2SS Convertible -Same as above except orange.
SomeGeoffGuy is offline   Reply With Quote
