Old 02-08-2021, 01:11 PM   #1
joekd
Drives: 2018 Camaro SS vert
2018 2SS vert, under hood almost done
Car was 100% stock when I bought it. First I had the OEM strut bar powder coated red/black, then redid the coil covers in red with black lettering. Then I painted the plenum cover, airbox lid and fuse box cover metallic black. Deleted sound tube and added the Airaid intake with green filter.
Next I added RGBW LEDs under the fuel rails and along the bottom of the strut bar. Just finished adding the coolant tank cover and repainted the corner appearance covers I had made to match the other pieces.
Next up I am planning to hydrodip a spare plenum cover I have and then should be done.
joekd is offline   Reply With Quote
Old 02-09-2021, 01:29 AM   #2
The_Dudebozo
Drives: 2016 2SS
Looking great; would you swap out the caps for color matching (coolant, windshield wiper fluid, oil cap etc)?
2016 Camaro 2SS A8 MRC NPP Sunroof. Addons: Stainless Works Redline axle back exhaust, Chevrolet cold air intake, C7 sideskirts/front splitter, Diode dynamics side markers
The_Dudebozo is offline   Reply With Quote
Old 02-09-2021, 03:55 AM   #3
peteric
Drives: 2016 camaro
Awesome. Where did you wire the LEDs?
peteric is offline   Reply With Quote
Old 02-09-2021, 08:27 AM   #4
joekd
I already painted the oil dipstick because that hideous yellow had to go, the rest I don't mind because they blend in
Old 02-09-2021, 08:29 AM   #5
joekd
Thanks, hot lead to terminal off underhoodnfuse box, ground to jump post in front of box.
Also wired a pin switch on the ground lead so they turn on with hood open
