![]() Drives: 2018 Chevy Camaro Join Date: Aug 2020
Tire suggestions?
My stock goodyear tires are about done so l am looking into what tires to get next. I have dedicated winter tires so looking at summer or aggressive all season tires. Any suggestions? Also would 245/45/20 tires work on the stock RS wheels rather than the usual 245/40/20?
USCG Retired (MKC)
Drives: 2018 2SS 1LE Black Join Date: Aug 2018
This has been covered untold times, do a search or start in the 'Tire and Rim' forum on this site. https://www.camaro6.com/forums/forumdisplay.php?f=227
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
Well if you have a winter tire sets then get a summer set not all season. There’s a wide variety of selection of tires out there and is usually based on how much money your willing to spend. Myself I was not happy with tire selection till I went to the R888’s and I would recommend them. Edit: I was basing this off thinking you where a SS but the 245’s are a sign your not.
Take a look at the Nitto 211070 | Nitto NT555 G2 Tires - 245/45R20
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro V6/RS Join Date: Nov 2018
The sjighly taller tire would work, but will throw the speedometer off a little
#5 | |
I like having all-seasons for summer. With those you can be lazy about when to switch over in fall. With the harder summer-only rubber you have to worry as soon as it gets cold. If I lived in florida year-round, then, yeah, summer tires would be it. |
![]() Drives: 2019 2SS 1LE Join Date: Aug 2019
I agree with everybody saying do a bit of research - there's no "best tire" - you'll have to better understand and tell us what you want out of a tire before we can help you.
In terms of a 45 series tire vs a 40, why do you want a taller tire? Is there a particular reason or is there just some tire that's not available in the smaller size? |
#7 |
If you really need the best dry/wet street and road course tire, these two tires (Michelin and Continental) work really well https://tirereviewsandmore.com/miche...xtremecontact/
The Nitto 555RII also might work for you. My experience is that the stock Goodyear Eagle F1 Supercar 3R are basically dry track-only.
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO. 15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR. 100 octane: 1045hp/1055tq. 100 octane + Alky MAF Meth (1) 10+: Last edited by JSH; 02-07-2021 at 09:05 AM. |
#8 |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
^^^ I suspect that OP's Goodyears aren't the 'R' kind.
aaron - taller tires on the same wheels will generally feel "softer" for both ride quality (maybe a good thing) and cornering response/steering precision (not such a good thing). They'll also sit the car up a little higher, and it'll probably be by enough to notice as you get in and out. They also take up more space, which is something you'll have to consider if you have any thoughts of lowering the car. Norm
'19 WRX 6M (the family sedan . . . seriously) |
#9 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
Michelin Pilot Sport 4S. No reason to change aspect ratio, stay with factory specification.
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
Agree with the above reply! Just get the factory sizes and drive on. �� You can do a size comparison on TireSize.com to see the difference in width and height of the size you are thinking about getting verses the stock OEM size.
#11 | |
![]() Drives: 2021 LT1 Join Date: Aug 2020
Doesn't this forum have moderators to move posts into correct forums? |
#12 | |
#13 |
I hope not
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO. 15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR. 100 octane: 1045hp/1055tq. 100 octane + Alky MAF Meth (1) 10+: |
#14 | |
| Tags |
| fitment, tires |
