Old 02-06-2021, 03:11 PM   #1
LloydK
Drives: 2020 SS Camaro A10
ATI Underdrive Pulley
What tool is needed to hold the crank for removal and install of the balancer for a 10 speed automatic ?
LloydK is offline   Reply With Quote
Old 02-07-2021, 07:00 PM   #2
Kevin01Z28
Drives: 2018 Camaro 2SS
Look online for a flywheel/flexplate holding tool (assuming you can’t find one local). There are many manufacturers that make them, they all work the same. Remove the starter, put the tool in place, bolt it down...remove the ridiculously tight balancer bolt.
2001 Z28 Full bolt on’s, ported 243’s, small cam, FMVB TH400 w/3,800 hard hit stall, 3.42’s. *sold* 😔
2018 SS Camaro A8 1LE replica wheels, bone stock otherwise
2008 F150 Daily driver
2002 Heritage Softail Classic 1.5 inch lower progressive rear springs/monotube fronts, 13" apes, 21" front mammoth spoked wheel, SE 10.5 cr heads, SE 264 cams, Mikuni HSR 42 flatslide carb, V&H pipes
Kevin01Z28 is offline   Reply With Quote
Old 02-15-2021, 05:35 PM   #3
Evansa22
Evansa22's Avatar
Drives: 2018 HBM ZLE
Anyone have recommendations on a tool to pull the balancer off? Getting ready to swap it on a zl1
