Old 02-06-2021, 03:21 PM   #1
ud03803
ud03803's Avatar
Drives: 2018 Camaro 1SS Blue
Visually Inspect TB Open
I tried searching the site for this but no luck. I am trying to confirm my tb is opening 100% visually. I know these are electronically controlled. The procedure I tried was doing a full power on, holding the start button. Then I had someone press the accelerator all the way down. But the throttle only opened maybe 50%. I am concerned my nitrous plate is interfering. Is there a procedure I can do to visually see it open to 100%?
CNC Ported 12:1 Heads/Kooks 1 7/8"/Hellion custom cam/Atomic MSD/Tony Mamo V2 PTB/K&N CAI/E85/All LT4 Fueling/Mystery Axle-back/Gap Juice
ud03803 is offline   Reply With Quote
Old 02-06-2021, 04:31 PM   #2
BruceWayne1LE
BruceWayne1LE's Avatar
Drives: 2018 Camaro SS 1LE M6
I’m curious if you could connect the maf tube to the TB with a small coupler and just look into the TB. No filter
Camaro 2SS 1LE, MBRP Catback, Mishimoto Catch Can, Rotofab dry, TSP1 7/8” headers,DSX FF, Pray ported MSD, 95mm TB
492WHP 473WTQ
BruceWayne1LE is offline   Reply With Quote
Old 02-06-2021, 04:53 PM   #3
6spdhyperblue
Drives: 2SS 1LE
Use your finger to open the blade?
All you’re doing with the motor off is initiating flood clear
Old 02-06-2021, 05:37 PM   #4
ud03803
ud03803's Avatar
Yes, I can do that and it appears to open all the way without obstruction when I do it with my hand. So I'm sure the nitrous plate is clear. I was just curious if it's normal to not go full throttle when the engine is not running but power is fully on. The plate does move, but only to 43% according to HP Tuners. I have confirmed in my logs when driving at WOT the accelerator is 100% while the throttle is at it's typical 83.9%. I wish HP Tuners would change that so at WOT it would read 100% if it really is. Thanks for the input.
Old 02-06-2021, 05:51 PM   #5
Karl Carson
SHRFT
Drives: 2017 2SS vert 50 anniversary
It's not recommended that you manually move the blade in the TB. Apparently that will force some small gears in the actuator to turn in a way they were not meant to move, possibly causing damage. Believe me I was tempted when I had my TB off.
Even though all the mosquitoes are roasting in HELL, I still don't like winter.
Karl Carson is offline   Reply With Quote
Old 02-08-2021, 09:11 AM   #6
squish72
Drives: 2016 2SS 8AT
When I ported my tb, I removed the black plastic electronics plate. They are built super burly with large gears and I physically moved it manually 1000s of times. Don't be afraid of breaking anything by doing it. The position sensor in them is even contactless.
squish72 is offline   Reply With Quote
