Old 02-05-2021, 11:45 AM   #1
PontiacBandit
Drives: 2021 Camaro LT1
Need Help—Camaro Stuck In Snowbank
Hey everyone! I know this is a weird one, but I need to have someone tow my Camaro from a snowbank. The way it is situated I think the only way that it can be pulled out is from the rear. I did a search and saw that there is no dedicated hook in the rear of the car for this. Does anyone have a good solution of where the tow truck driver might be able to attach or wrap a strap? I don’t want anything to break and I’m not sure that I trust a regular tow driver to get this right.
Luckily, it’s just in my driveway. Tried to get it unstuck from its spot on the driveway and ended up sliding off the side.
Thanks in advance!
PontiacBandit is offline   Reply With Quote
Old 02-05-2021, 11:51 AM   #2
kevint
Drives: 2013 1SS
Based on a quick search there appears to be no provision for a rear tow hook. The guys who trailer seem to like tying the car down by putting the straps through the rear wheels.
kevint is offline   Reply With Quote
Old 02-05-2021, 12:22 PM   #3
Jsreo
Drives: 2017 2SS Manual
Posting a picture might be helpful so we can see exactly how it is stuck
Jsreo is offline   Reply With Quote
Old 02-05-2021, 12:30 PM   #4
FarmerFran
FarmerFran's Avatar
Whiskey
Tango
Foxtrot
Old 02-05-2021, 01:02 PM   #5
gtfoxy
Drives: '21 Wild Cherry ZL1
This right here is why some of us choose not to drive their Camaro in inclement road & weather conditions.
Hope you can get it fished out, OP, with out anything being damaged.
Old 02-05-2021, 01:25 PM   #6
ctrlz
I would go to one or both of the points where the lower control arm attaches to the crossmember. Immediately to either side of the pre-muffler tailpipe in this photo.
You might need to do some digging, and you need to make sure the tow line doesn't damage anything once it straightens out under tension.
I am assuming this is an accurate photo of a gen6.
https://www.google.com/imgres?imgurl...MygCegUIARCwAQ
Old 02-05-2021, 01:42 PM   #7
kevint
Drives: 2013 1SS
This was my other thought as well. It's probably the most rigid part of the rear.
Old 02-05-2021, 01:56 PM   #8
ctrlz
I would avoid letting them pull on a wheel. That's going to put a lot of force on suspension components in a way there were not designed to handle.
Old 02-05-2021, 02:12 PM   #9
90503
90503's Avatar
Drives: 2011 2SS/RS LS3
Maybe helpful...or too little too late...Good luck.
https://www.camaro6.com/forums/showthread.php?t=465350
Old 02-05-2021, 02:18 PM   #10
jamala00
jamala00's Avatar
Drives: 2016 Camaro 2SS Hyper Blue Metallic
^^^I could not agree with this post more...
OP... hope you figure out a way to get it out.
jamala00 is offline   Reply With Quote
Old 02-05-2021, 02:25 PM   #11
NotFast
Drives: 2021 LT1
As someone who spun their Corvette on dry, 40 degree sunny day pavement: I feel for you.
NotFast is offline   Reply With Quote
Old 02-05-2021, 04:15 PM   #12
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
Thanks in advance!
Any chance that you can get some sand, cat litter, or some other traction enhancements under the rear tires and carefully drive out?
Old 02-05-2021, 04:41 PM   #13
Bob RS
Drives: 2019 Camaro RS 1LT
I would try using rollers like the ones they use in body shops under both rear tires and then strapping the wheels and very slowly pull her out.
Bob RS is offline   Reply With Quote
Old 02-05-2021, 06:15 PM   #14
NYJets12
NYJets12's Avatar
Drives: 2018 1LT Camaro
A picture would be good but why not just shovel the snow out from all 4 tires and put some ice melt under each tire put it in snow/ ice mode and go for it.
NYJets12 is offline   Reply With Quote
