![]() Drives: 2021 Camaro ZL1 A10 Join Date: May 2013
Interior Fan comes on full blast.
When I start the car. The interior fan immediately goes on full power. I have to turn it down to about half speed. After a drive, I will shut the car down at about half speed setting. The next time I start the car, the fan is blowing at full power.
Is this unusual? If so how do I correct it? |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
I feel like there is a setting for that
![]() Drives: Chevy Camaro Join Date: Apr 2020
If you have a temp set and the climate controls set to auto it will come on full blast until it reaches that temp
On the touch screen you can set things under auto climate. My fan is on medium.
Howdy! Pete here...
Drives: 2017 50th Anniv 2SS, A8, NPP, MRC Join Date: Jul 2009
Take your climate control system off of Auto or change the default fan speed in the vehicle settings.
PnCRedJwl2SS
2017 50th Anniversary Edition, A8, NPP, MRC, w/Sunroof and Glow-tie! ___________________________________________ ___________________________________________ Ordered from GM Delivered to dealership and home 9-16-16 This car is a beast! |
Drives: Fast if no one's looking Join Date: Aug 2019
If your base trim is a 2SS (I don’t know if ZL1s are all 2SS or can be 1SS that’s why I ask) there is a setting in the climate control sub-menu settings where you can adjust the fan speed in auto mode
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
Check your settings in the DIC like was replied above. I think yours in on Auto and I’m pretty sure that would cause the fan to come on full blast.
#8 | ||
Settings -> Vehicle -> Climate Control -> Auto Fan Speed -> Low, Medium, or High |
#9 |
Thanks to you all.
This has never happened in any of the cars I have owned previously. |
#10 |
This was pretty weird for me too. I’ve never imagined they would actually design a settable default fan speed for when you’re in auto mode. Every other car with climate control, you press auto and the fan varies from full blast to barely on all by itself.
#11 |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
Hmmm, I might have to look at this to see if there is a setting that effects remote start fan speed.
I can have it on high when on, but w remote start it is on low. |
#12 |
#13 | |
Now both our clutch and brake pedal send signal to the ECM, and if you Hotwire the brake pedal signal switch the brake lights would stay on all the time |
#14 | |
