Old 02-01-2021, 08:51 PM   #1
BruceWayne1LE
BruceWayne1LE's Avatar
Drives: 2018 Camaro SS 1LE M6
Nasty intake valves
Anyone know if it’s possible to clean the intake valves while on the car? Had the manifold off and took a peak inside. Had some gooey tar looking buildup on the bottom third of the stem.
Camaro 2SS 1LE, MBRP Catback, Mishimoto Catch Can, Rotofab dry, TSP1 7/8” headers,DSX FF, Pray ported MSD, 95mm TB
492WHP 473WTQ
BruceWayne1LE is offline   Reply With Quote
Old 02-01-2021, 10:16 PM   #2
UnknownJinX
UnknownJinX's Avatar
Drives: 19 Chevrolet Camaro 2SS 1LE Shock
Generally, people use walnut shell blasting to address the carbon buildup.
That said, I believe GM addressed the carbon buildup issue before. They mentioned that it is mostly just aesthetic. The buildup doesn't meaningfully impact performance.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock
GM Performance Intake and that's it, because driver mods before car mods
Past:
2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold)
2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled)
UnknownJinX is offline   Reply With Quote
Old 02-01-2021, 11:11 PM   #3
BruceWayne1LE
I’ve had my catch can on since about 8k miles. It was just kinda ugly. I did see a video that I think Mishimoto posted of some jackoffs using compressed air and a wire wheel inside the intake port. THAT made me want to head butt a knife.
Anyway, maybe next time I have the manifold off I’ll use some carb cleaner and a vacuum.
492WHP 473WTQ
Old 02-02-2021, 01:09 AM   #4
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
How many miles do you have now?
Old 02-02-2021, 01:43 AM   #5
Ademarco
Drives: 18 Ford Raptor, 21 2SS 1LE M6
Another member from Canada has 175k miles and had the same buildup, but no issues for him.
Ademarco is offline   Reply With Quote
Old 02-02-2021, 09:45 AM   #6
BruceWayne1LE
26k. Seemed a little much for “low” miles. I should have taken a picture when I had the manifold off😕. Next time.... carb cleaner toothbrush and a vacuum.
492WHP 473WTQ
Old 02-02-2021, 09:50 AM   #7
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
Just give it the "Italian Tune Up", you can get the intake valve temps over the point deposits form and it'll help burn them off.
Old 02-02-2021, 11:15 AM   #8
NeverDie
Drives: 2017 Camaro SS 1LE
Can you?
NeverDie is offline   Reply With Quote
Old 02-02-2021, 11:19 AM   #9
BruceWayne1LE
I can retaliate against my a**hole neighbor who like to make car videos of him bangin the rev limiter in his McLaren at midnight. Feed this puppy some 100* and see what happens
492WHP 473WTQ
Old 02-02-2021, 11:36 AM   #10
DaveC113
DaveC113's Avatar
Originally Posted by NeverDie View Post
Can you?
Yes, that video supports this view.
Old 02-02-2021, 01:18 PM   #11
UnknownJinX
Jason did mention that it works on PI engines, but not necessarily on DI engines. He even said that it can actually worsen the issue on a DI engine from the Italian tune-up.
Realistically, you won't get the intake valves hot enough unless you are hitting a track.
I mean, it's not like you are going to look at the intake valve all day. If there is a little bit of buildup, I wouldn't lose sleep over it.
Sent from toaster or something
Current:
Past:
Old 02-02-2021, 02:00 PM   #12
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
no catch can here and i track my car wonder what mine look like lol
Old 02-02-2021, 02:13 PM   #13
BruceWayne1LE
Yea I figured it’s not a huge deal it was just ugly. Now my 2002 Ford Explorer was disgusting. I had my brother hold rpms at 5k while I dumped an entire can of carb cleaner into the intake. Did it work? Idk. But it didn’t blow up and I just tapped 300k.
492WHP 473WTQ
Old 02-02-2021, 02:14 PM   #14
DaveC113
DaveC113's Avatar
It definitely works on DI engines.
The issues VW had with their engines were highly dependent on driving habits. Our 6.2L has a stock air/oil separator and new oils are less volatile so maybe it doesn't matter but you can definitey get the intake valves hot enough on the street.
