![]() Drives: 2016 2SS 6MT Join Date: Apr 2020
No further tuning required for headers?
Basically I had a remote tune done for ported LT5 TB, ported intake manifold and a rotofab. After installing 2 inch catless headers, I sent my same tuner a log and he said it doesn't look like it needs a retune. Is this true? It looks to be running leaner than when I had the headers.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
Yes that’s pretty common
BL1ZZRD
Drives: '16 Camaro 2SS, '20 Equinox Redline Join Date: Jul 2009
Eventually you'll get o2 cel codes pop up until your tuner deletes the rear ones in the tune.
![]() Drives: 2017 Chevrolet Camaro SS Join Date: Jul 2020
Required? No, until the CEL pops for the rear o2's (if he hasnt already shut them off)
However to say that the same tune with factory manifolds will be as efficient as an updated file for the headers is incorrect. |
![]() ![]() Drives: 2021 Camaro LT1 Join Date: Sep 2020
I say a tune is a must if you want the most gains and no cel mel.
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
Agreed^^^!!!
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 2SS M6 Join Date: Jun 2013
dont get remote tunes. The torque based LT1 needs a dyno with a eddy brake to tune it find a dyno tuner who can properly tune your car. where in ny are you located? if near Buffalo J&J Speed Shop. you removed your stock cats you need a tune.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: like an old lady Join Date: Jun 2012
since you clearly don't trust your tuner, ask yourself this question:
how do his cars run? are they known for being strong or is he just another tuner? if the answer is not the first one, you chose wrong to start with. tune is paramount...and has been since the internal combustion engine fired its first cylinder. if there's no question of his work - take it and move on. worry about something else. without looking at your log file its hard to tell you what's right or not.
