Old 01-30-2021, 09:18 PM   #1
NA18CamaroSS
NA18CamaroSS's Avatar
Drives: 2018 Chevrolet Camaro 2SS 1LE 6M
American Racing Headers install note.
I finally broke down and bought the American Racing Headers long system. Installed it yesterday. It went smoothly, for the most part. I did not receive instructions with the system-I don't know if the system comes with them-so I was on my own. There was one problem that I encountered, so I thought that I would share my experience, in the interest of helping the community. In the photo of the system, I have circled the problem pieces.
The pipes that attach to the headers look identical, but as I found out, they are not. One pipe is roughly 10 MM shorter than the other. I unknowingly put the short pipe on the right and the longer pipe on the left. This created an interference issue with the transmission cross brace on the right side, and the left side was rubbing against the body. After sleeping on the problem, it occurred to me that the pipes might not be equal length. Today I pulled them out and sure enough, there was a slight difference in length.
Long story short, the longer pipe goes on the right, and the shorter pipe goes on the left. FYI.
PS: The system sounds incredible! Still running the factory NPP muffler to keep peace in the neighborhood.
Bolt-ons.
NA18CamaroSS is offline   Reply With Quote
Old 01-30-2021, 09:21 PM   #2
NA18CamaroSS
The system connects perfectly to the stock muffler.
Bolt-ons.
Old 01-31-2021, 12:19 AM   #3
SS_1LE
Drives: 2020 SS 1LE
Right as in passenger side? Left as in driver side?
SS_1LE is offline   Reply With Quote
Old 01-31-2021, 01:41 AM   #4
Dvs510
Dvs510's Avatar
Drives: 2018 Camaro SS/1LE
Thanks for sharing.. good info to know... by chance do u remember where exactly the long system stopped or where u cut the stock pipe?
2018 SS/1LE... summit white.. E85 ,Ported LT2 IM, Roto Fab, soler performance ported throttle body, secondary delete, mbrp axle back, tuned by CCNC
Dvs510 is offline   Reply With Quote
Old 01-31-2021, 02:07 AM   #5
NA18CamaroSS
Look at my second post in this thread-you can see where the stock muffler connects to the long system. There is ~ 16-18 inches of piping going from the muffler to the ARH long system. I cut the muffler piping at the end of the restriction and then mounted everything up to check fitment. It was necessary to cut about another inch off of the muffler piping to mate it to the ARH system.
Yes.
Bolt-ons.
Old 01-31-2021, 02:08 AM   #6
NA18CamaroSS
Look at my second post in this thread-you can see where the stock muffler connects to the long system. There is ~ 16-18 inches of piping going from the muffler to the ARH long system. I cut the muffler piping at the end of the restriction and then mounted everything up to check fitment. It was necessary to cut about another inch off of the muffler piping to mate it to the ARH system. I attached a shot here of just the junction of the stock muffler with the ARH system.
Yes.
Bolt-ons.
Old 03-21-2022, 03:51 PM   #7
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Man... I REALLY wish I would have seen this before yesterday... Spent hours on my back trying to get this system to align, and now i see i made this mistake. I cant believe this system failed to provide proper instructions, or labels on parts... i have about .25" between the passenger side cap pipe and the trans brace.... does everyone agree that it will rub, or should I try to drive it first? Also, are the clamps going to prevent leaking, or does everyone weld their system?
I will say, that the 6 hours to install the BMR motor mounts allowed the headers to slide in just 1 minute per side
Old 04-04-2022, 06:24 PM   #8
RobbyBeefcake87
RobbyBeefcake87's Avatar
Drives: 2018 Camaro SS 1LE
Did the bmr motor mounts lower then engine any?
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler.
2018 Colorado zr2 - zr2 sport bar, showcase spare tire.
2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace.
2017 Corvette Grandsport (sold) - untouched.
2006 GTO (sold) - iat relocation, air box mod, monero side marker lights.
RobbyBeefcake87 is offline   Reply With Quote
Old 04-04-2022, 11:29 PM   #9
SOCAL.M6.ZLE
Hmmmm, I cant say that i checked, but my memory says no. I did raise the engine a bit, but i recall the new mounts fit perfect.
I will say that the car runs like shit after everything I installed, and it really needs a tune. I am worried that the mounts are causing alot of KR, but i need to install my wideband o2 and JMS BAP first before we can datalog... stay tuned.
Old 04-05-2022, 07:44 AM   #10
Spaceme1117
Spaceme1117's Avatar
Drives: 2017 Camaro SS, 2011 Corvette GS
This and fitment of ARH on my C6 Corvette is why I will never buy ARH again or recommend them to anyone. No instructions and no labeling of the parts to ensure there are no install issues is unforgiveable for what is supposed to be a high-end and very expensive product.
Never had any problems with Kooks (five different cars with Kooks). Always fit, always include instructions, and the parts are labeled.
Spaceme1117 is offline   Reply With Quote
Old 04-05-2022, 08:21 AM   #11
Spaceme1117
Old 04-19-2022, 11:51 AM   #12
RobbyBeefcake87
I'm surprised you're running it with those mods and it's not throwing codes or going into limp mode whenever you hit it... assuming you hit hard from time to time, which ideally you aren't lol.
Thanks, good to know the mounts don't really cause an issues with the manuals trans and shifter fitment.
