Old 01-27-2021, 01:04 PM   #1
Xyebo
Xyebo's Avatar
Drives: '23 1SS 1LE | '18 1LS V6 [sold]
Is track alignment possible on FE2 suspension? (LS and LT models)
Hey, all
Does anybody have experience running a track alignment spec on the base Camaro models? (LS and LT trims, not 1LE)
I am talking about the alignment specs from high performance supplement (-1.5 camber front, -1.25 camber rear): https://www.camaro6.com/forums/showpost.php?p=10113865&postcount=37/
How does the car feel, is the tire wear okay with the stock 245s?
Xyebo is offline   Reply With Quote
Old 01-27-2021, 01:46 PM   #2
foshjowler
foshjowler's Avatar
Drives: 2017 Camaro 2.0T, 91 Miata
I believe the FE2 shocks/struts are dimensionally the same as FE3, just different valving. So anything you can do with FE3 you should be able to do with FE2.
For tire wear, I don't have the stock 245s, but run -2.5 F and -2 R (with camber plates) and haven't seen any meaningful extra wear.
305 BFG Rivals FTW
Youtube Channel
foshjowler is offline   Reply With Quote
Old 01-27-2021, 02:33 PM   #3
Xyebo
Xyebo's Avatar
Thanks!
How negative were you able to go without the camber plates?
Old 01-27-2021, 03:45 PM   #4
foshjowler
foshjowler's Avatar
Originally Posted by Xyebo View Post
Thanks!
Never tried. When I put the 305s on there isn't much room to the strut, so I knew I had to get camber plates. There's plenty of adjustment on the knuckle, so I would think -1.5 wouldn't be an issue.
305 BFG Rivals FTW
Youtube Channel
Old 03-15-2021, 02:22 PM   #5
juansheba05
juansheba05's Avatar
Drives: 2017 V6 1LE
I was able to get -1.9 camber front and -1.6 camber rear without any camber plates.
I could tell the difference in autocross for sure.
Tire wear is not bad, I've put around 4k miles on stock all-season tires and there isn't any evident wear.
For autocross I run Re71-r 265/40/R19 all around and I wish I could get more negative camber but that's as far as the shop could go without messing toe too much.
juansheba05 is offline   Reply With Quote
Old 03-18-2021, 11:03 AM   #6
JayRow52
JayRow52's Avatar
Drives: 2017 Camaro 1LS 2.0T
I ran -1.5f & -1.3r with the stock 245s and FE2 suspension for a year without any extra wear - approx. 3,000 miles. Added the FE3 suspension the next year and did another 2,000 miles with the same alignment specs. Last year I bumped it up to -2.0f & -1.6r with 265/45r18 Pirelli PZ4s (toe is just under 0.1). 2,500 miles and counting with minimal extra wear on the inside shoulder.
The car handles great on track, canyons, and around town. Turn in was much more responsive when I switched to the Pirellis and newer alignment specs. Those happened the same day so I'm not sure which is responsible (maybe both).
Modifications: 1LE (FE3) Suspension, Chevy Performance 4-Piston Brembo Kit, Kansei Corsa wheels w/ Pirelli PZ4 265/45r18
JayRow52 is offline   Reply With Quote
Old 03-21-2021, 03:01 PM   #7
Xyebo
Xyebo's Avatar
Thanks for everybody's input.
The alignment fella was able to get me -1.5 front camber and -1.25 rear camber without any issues.
