Old 01-27-2021, 07:57 AM   #1
74z/28
Drives: Looking
Trailering questions
Hi all. I am looking for an A10 ZL1 and have a few questions related to trailering one back home. Since I live in Northern Illinois, driving it home at this time of year is not an option. I am working on a deal on a car that is 650 miles from home. I have a dual axle (7000 lb) 18' x 7' utility trailer that I modified to use as a car trailer. I put E-track on it and have 4 wheel straps and wheel chucks to secure the car to the E-track. The issue is the trailer has 1' high rails that are not removable, so I can't open the door while the car is on the trailer. I have a wench mounted to the trailer so I can wench the car up with the factory tow hook. My questions are:
1. Can the A10 cars be shut off in neutral so I can wench the car up onto the trailer?
2. If I left the drivers window down, would there be enough room to reach through the little window and engage the e-brake, or better yet, put it in Park?
3.I would also need to be able to roll the window up for the trip home. Would I be able to reach through the window with the key fob and cycle the ACC, RUN and OFF modes and roll the window up from outside the car?
4. I am too fat to crawl out through the trunk with the back seat down. If the above will work then I will have my 12 year old son crawl through the trunk when we get the car home and disengage the parking brake or put the car back in neutral. Does any of this make sense to anyone?
5. Does anyone have a better idea here that I missed?
Thanks in advance for any help here.
74z/28 is offline   Reply With Quote
Old 01-27-2021, 03:43 PM   #2
ponyboy96
ponyboy96's Avatar
Drives: 2020 ZLE A10, 2018 F250 Diesel
1. Yes
2. Yes
3. Yes
4. The backseat doesn’t fold down
5. There is a remote window down function on the key fob, so you could use that to roll down the window.
ponyboy96 is offline   Reply With Quote
Old 01-27-2021, 04:26 PM   #3
PROMETHEUS
PROMETHEUS's Avatar
Originally Posted by ponyboy96 View Post
1. Yes
2. Yes
3. Yes
On the ZL1 the backseats do fold down. I believe the ZLE, they do not.
Old 01-27-2021, 04:40 PM   #4
Blast2hell
Drives: 2020 ZLE Rally Green A10
Can you possibly put a towel or something soft down and at least be able to open the door a little? I'm a pretty big guy, but I got an enclosed trailer and this is what I do to make enough room for me to squeeze out the window.
2020 Rally Green ZLE A10
(SOLD)2017 NGM ZL1 A10 Built 3/31
Sebring Best Lap Time 2:29 Video
Roebling Road Best Lap Time 1:25 Video
Blast2hell is offline   Reply With Quote
Old 01-27-2021, 04:48 PM   #5
Stevezx900
Stevezx900's Avatar
Drives: Buick Grand National, BMW M5
They fold down on the ZLE also.
I found this out via the forum last week.
Stevezx900 is offline   Reply With Quote
Old 01-27-2021, 07:26 PM   #6
Hot454
Drives: 2017 Camaro ZL1
I don't have the car yet, how do you roll the windows down with the remote? This is a 2018, is there a dedicated button the remote for that?
Hot454 is offline   Reply With Quote
Old 01-27-2021, 11:49 PM   #7
Max2075
Max2075's Avatar
Drives: 2004 Z06, 2018 ZL1 1LE
Confirm that the back seat folds down in zl1 1le also. you have to lift a cloth cover on the back of the seat that you can see through the trunk. I use a 1/4 drive 6 inch extension to push the lever that unlatches it. I do it every time I load the car on the trailer to store track gear in the trunk. Your son can sit in the car while you load it up and then roll up the windows, set ebrake and put it in park and climb out trough the trunk.
Max2075 is offline   Reply With Quote
Old 01-28-2021, 12:18 AM   #8
Max2075
Max2075's Avatar
Pics of the latch with the seat folded down. I also confirmed the roll down feature by holding down the unlock button on the remote. I checked it with the ebrake on and I am not sure if it works with ebrake off. Mine is a 2018 zl1 l1e 6 speed with no remote start. But I don't think there is a roll up option.
Old 01-28-2021, 02:07 AM   #9
ohsmily
Drives: '19 ZL1 1LE A10 ShadowGrayMetallic
You must have some burley women around you if they can get your car up a ramp into a trailer. Wow.
ohsmily is offline   Reply With Quote
Old 01-28-2021, 02:37 AM   #10
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
Climb out through the trunk? The Dukes of Hazard had no problem only entering/exiting General Lee through windows while running from the Sheriff, I think his son can manage the same without damage.
SFV1LE is offline   Reply With Quote
Old 01-28-2021, 10:26 AM   #11
MoreSpeed
MoreSpeed's Avatar
U-Haul rents a car trailer that works fine for our cars for about $54 ad day. You just need some wood to raise the front so there is no scraping.
- Life is a highway... I want to ride it all night long...
Sold 2010 997 GT3, 2016 WRX, 2006 997 C2S, 2003 996 C4S, 2001 Boxster S, 1997 E420 AMG
etc..
MoreSpeed is offline   Reply With Quote
Old 01-28-2021, 01:46 PM   #12
Max2075
Max2075's Avatar
For sure. So could I, but the window still needs to be rolled up. It can be done reaching around the door when partially open if there is enough room. The trunk is a good back up plan.
Old 01-28-2021, 02:35 PM   #13
Vigilante375
Drives: 2018 Camaro ZL1
I'll have to look but I think it's a feature you have to enable from the vehicle settings.
Once you enable it, all you have to do is hold down the unlock button for a few seconds and the windows will roll down.
The car might need be unlocked first but I'll try it later
Old 01-28-2021, 03:39 PM   #14
Vigilante375
So the feature is under settings, vehicle then the remote start option. Look for remote window operation and turn it on.
Even with the car locked, you can press and hold the unlock button to lower both windows. I just did it on my car with it locked.
Don't forget to take the two plates off so it doesn't crush your front bumper and underside.
