Old 01-26-2021, 04:45 PM   #1
Orlando_ZL1
Drives: 2019 Chevrolet Camaro ZL1
Misfire, Service Stabilitrak, Service Rear Axle
I have a 2019 ZL1 A10 with 3,500 miles and my engine has been misfiring. I took it to my dealership and they have replaced the coils, spark plugs, and injector, but the problem is still not fixed. Has this happened to anyone else before? If so, can you please share the solution?
Orlando_ZL1 is offline   Reply With Quote
Old 01-26-2021, 05:12 PM   #2
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
MISFIRE cylinder 2 and stabiltrak error
YEP. The issue was a broken valve spring on an engine that only had 500 miles on it. Apparently at some point in time, GM's valve spring provider had a bad batch of them The dealer replaced all the valve springs. The stabiltrak error went away also. Fortunately the valve DID NOT drop down into the engine or that would have meant BYE BYE LT1. The SES light began to flash once the misfire was detected so at that point in time I limped it into the dealer.
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is offline   Reply With Quote
Old 01-26-2021, 05:57 PM   #3
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
FYI you will get stabilitrak fault with misfire codes, ignore the stabilitrak fault in the presence of misfires.
Old 01-27-2021, 07:39 AM   #4
Bangkok_ZL1
Flying around Thailand
Bangkok_ZL1's Avatar
Drives: 2019 Camaro ZL1
Damn, I hate hearing this. I thought it was not happening on our year, 2019. Please God don't let me be cursed with this BS. I have about 4000 miles on mine now.
Bangkok_ZL1 is offline   Reply With Quote
Old 01-27-2021, 10:58 PM   #5
Orlando_ZL1
Once you got to the dealership, was it an easy fix? I suggested the valve spring, but they just keep replacing parts.
Old 01-28-2021, 11:43 AM   #6
Bangkok_ZL1
By the way, is this while idling or were you driving and it was misfiring. because mine misfires while idling all the time. However, it's worse when the engine warms up. But when I'm driving, it never misses a beat.
Old 01-28-2021, 12:40 PM   #7
Akirasoft
Drives: 2018 ZL1 1LE, 2015 X3 x35i M-Sport
I had a similar suite of errors during an HPDE after getting headers put on. Turned out to be caused by the harness melting due to it contacting the header...
Akirasoft is offline   Reply With Quote
Old 02-03-2021, 04:39 PM   #8
Orlando_ZL1
I was misfiring while idling and driving. My dealership still has my car and they continue to replace parts on it.
Old 02-03-2021, 07:42 PM   #9
Scottyz
2019 ZL1 1LE MY GOON
Scottyz's Avatar
Drives: 1980 Z28 Big Red.
Tell them again to yank the valve covers for a look at the springs.
Old 02-03-2021, 07:43 PM   #10
Scottyz
Scottyz's Avatar
If I were you I would check to make sure the plug wires are fully seated. If the wires are fully seated, then I would toss in a new set of plugs.
Old 02-04-2021, 10:31 AM   #11
Orlando_ZL1
I have already suggested that, but they are either ignoring me or they already tried it. They keep ordering additional fuel injectors.
Old 02-04-2021, 11:00 AM   #12
DangerZL1
Drives: 2023 Black ZL1 Auto
Doesn't the scan tool show which cylinder is misfiring, or is it randomly in all of them?
Old 02-06-2021, 10:59 PM   #13
Bangkok_ZL1
Thank You, I will check for proper seating and when I get JRE 125 kit (comes with new plugs), the plugs will be changed. I'm still trying to get a bead on a set of headers from Australia since my ZL1 is RHD.
Old 02-08-2021, 01:25 PM   #14
Orlando_ZL1
It occurs in 3, 5, and 7. They replaced the three fuel injectors. GM told them to replace the fourth fuel injector in the bank.
