Old 01-26-2021, 03:38 PM   #1
AmazinglySmooth
Drives: 2018 Camaro SS 1LE
Goodyear replacement depth
I feel the fronts are too worn on my 1LE. The outer edge is slick. The inner edge looks just ok. At what depth do you swap these tires? They start with 7, so if you replace them at 4 or 3, you haven't gotten much life out of them.
AmazinglySmooth is offline   Reply With Quote
Old 01-26-2021, 04:17 PM   #2
Rhobz
Rhobz's Avatar
Drives: 2018 Camaro 1SS 1LE
I probably have about 0.5 and am starting to think about replacing them.
I have just under 11000 miles, mostly spirited canyon type driving.
Rhobz is offline   Reply With Quote
Old 01-26-2021, 04:59 PM   #3
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
when they got cords showing lol
Old 01-26-2021, 06:27 PM   #4
Scargoes
Scargoes's Avatar
Drives: '18 Hyper Blue 2SS1LE '20 Crush RSR
The thing to remember is that the outer two tread blocks become one at about 4.5mm depth. Only way to know how much is left is to check the tread depth holes that are molded into the tread. Look for some rectangular holes near the edge. That is where you take a tread depth measurement.
Edit: I have circled in red the holes you should look for. The groove identified by the green line is not as deep as the other grooves. This is so as the tire wears the outer edge becomes more like a slick with less voids and less tread squirm.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:28.95 Willow Springs Big Track
Scargoes is offline   Reply With Quote
Old 01-26-2021, 07:33 PM   #5
weemus
Drives: 2017 1SS 1LE
+1 when the cords show
But I’ll add that I drive my wife’s car in the rain when the tires go near slick then I run them in dry weather until cords show.
weemus is offline   Reply With Quote
Old 01-26-2021, 08:38 PM   #6
MatthewAMEL
MatthewAMEL's Avatar
When they cord.
My fronts always cord inside edge 1st.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
2025 Hysteria Purple
C8 Z07
Old 01-26-2021, 09:38 PM   #7
MatthewAMEL
BTW - that is the result of two road trips from Orlando to Boone, NC to VIR (two days at VIR) back to Boone, back to Orlando and then a month later up to RRR in Savannah. All of that was with -2.5F camber.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
C8 Z07
Old 01-26-2021, 10:43 PM   #8
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Either worn or heat cycled out... ideally when both happen at same time!
ing for grip.
http://www.motorsportsne.com/
Old 01-27-2021, 12:35 PM   #9
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Id run the wear bars/indicators than a depth measurement which with these kind of tires IMHO a measurement and whatever that standard for tread depth might, be isn't too applicable with these type tires.
Old 01-28-2021, 04:05 PM   #10
TRZ06
TRZ06's Avatar
Drives: 22' Porsche PDK GT4
I only drive on the street , albeit sporty street driving and I have the track alignment.
My wear rate is about 2:1 Rear to front. When the rears are slicks, I replace all 4.
Replacing all 4 keeps the car very neutral. As my rears wear, my car goes from neutral to slight oversteery. This last time, I only replaced the rears and I now have understeer.
Current:
Previous:
09' C6 Z06
08' E90 M3
06' 335i (KW V2 Coilovers)
03' C5 Z06
Old 01-28-2021, 05:22 PM   #11
TrackClub
TrackClub's Avatar
Originally Posted by MatthewAMEL View Post
When they cord.
Check your toe. Way too much rubber left on yours to chuck them otherwise. Here's pic of mine at 2.6 camber. Cheers!
Old 01-28-2021, 06:24 PM   #12
MatthewAMEL
Alignment was fine. It was the 4,000 highway miles that killed them. The VIR sessions didn't hurt, either.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
C8 Z07
Old 01-28-2021, 08:32 PM   #13
TrackClub
TrackClub's Avatar
Ya, abrasive track will cord them. That's what happened to me, but only once. Never had one cord just from DD. By and large camber wont cord a tire, but excessive toe will make fast work of it. I am running zero toe in the front now. No complaints regarding turn in etc. Cheers!
Old 01-29-2021, 07:54 AM   #14
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
Thanks for chiming in TC. Looking at all the rubber left on his tire pains me, but that is a lot of street/highway miles on a track alignment. Definitely agree on toe being the main problem, but I'd also like to see the outer edge because he might be able to go with less camber as well.
My obligatory tire photo to show you up
With all of that said, in regards to the OP, it doesn't seem like he is tracking the car if he doesn't know much about these tires. I would recommend buying different tires when the time comes and getting an alignment at the same time.
Old Ride: 2016 Callaway SC630 Camaro SS
