Old 01-25-2021, 01:50 PM   #1
Snakely
Snakely's Avatar
Drives: '21 Wild Cherry 2SS M6
Fender Badging
Preface - I haven't taken delivery yet, but my car is on order.
I'm thinking I would like to have the Camaro Script emblem on the fender, something like this... https://www.ecklers.com/camaro-fende...-366401-1.html
Assuming the factory emblems (2021) are stick on, what is the best way to remove those?
Also, if anyone one has any recommendations on specific vendors for said emblems, that would be great too.
-Travis
Snakely is offline   Reply With Quote
Old 01-25-2021, 01:52 PM   #2
RyanR623
Drives: SS A8, NPP, Red Hot
-Travis
Heat gun would be best, but if you don't have one, I always used strong fishing line. Being it's brand new, you may be able to just pull it off too.
RyanR623 is offline   Reply With Quote
Old 01-25-2021, 02:16 PM   #3
HCI2000SS
HCI2000SS's Avatar
Drives: 2018 Camaro V6/RS
I used dental floss and a hair dryer. Worked just fine
HCI2000SS is offline   Reply With Quote
Old 01-25-2021, 03:11 PM   #4
az4783054
Drives: SWXXZL1
Thin gauge fishing line with medium heat from a heat gun or hair dryer moving back and forth about 10" away. Then use a short stroke sawing motion. Repeat as necessary with the heat source. Avoid prying with any kind of tool. If any adhesive residue remains, roll it off with your fingers and/or denatured alcohol or a citrus based product. Polish/wax final.
The blisters heal in about a week.
"Joe" does a hilarious impression of a slinky toy on stairs.
az4783054 is offline   Reply With Quote
Old 01-25-2021, 03:21 PM   #5
sengli
sengli's Avatar
Drives: 2015commemorative vert 2SS
I the OEM camaro badging, they were easy to apply. Looked like they belonged there.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded
2015 commemorative vert 2ss
sengli is offline   Reply With Quote
Old 01-25-2021, 03:22 PM   #6
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Floss works well too...make sure the surface is warm (not hot) and don't use a heat gun, use a hair dryer on low.
Old 01-25-2021, 06:59 PM   #7
Jaysatthelake
Drives: 2019 2SS 6 speed convertible
Fender badge
Here's what I ordered from the factory on my 2019.
Jaysatthelake is offline   Reply With Quote
Old 01-25-2021, 07:35 PM   #8
-Travis
As mentioned before, a hair dryer or heat gun plus a fishing line works very well for removal. Once the emblem is off, carefully collect as much of the goop with your fingers as you can, then clean off the residue with Goo Gone and wipe the paint clean with 70%+ isopropyl alcohol.
As to the where to obtain these retro badges from, while I installed the GM heritage emblems (as you can see below), I've had much success in the past with the screaming chicken guys, here's a link to their retro collection: https://screamingchicken.com/1982-20...fender-emblems
Old 01-25-2021, 08:59 PM   #9
17rsvert
17rsvert's Avatar
Drives: 2017 HBM 2LT RS Convertible V6 A8
Bought mine on Amazon, but the listing is no longer available. It's Eckler's 33-336397
Peel off liner with adhesive foam. I was concerned with the quality, buying without seeing it first, but it doesn't look cheap and I'm pleased with the polished finish.
Got the original ones off with dental floss and a hair dryer, GooGone, alcohol. Located the new one on the driver side, and made a relatively large paper template to duplicate the exact location on the passenger side.
I've gotten a lot of positive comments from people who appreciate the retro-ness.
17rsvert is offline   Reply With Quote
Old 01-25-2021, 10:57 PM   #10
MackSteelPrivateEye
This looks better
This looks better.....
Old 01-26-2021, 07:16 AM   #11
Snakely
Snakely's Avatar
Thanks everyone! Looking forwarding to this.
Old 01-26-2021, 10:07 AM   #12
KirkH
https://www.emblempros.com/
They are a forum sponsor!
