Drives: 6 on the Flo' Super Sport Join Date: Jan 2011
Manual Trans Fluid
Anyone changed there manual trans fluid yet? I'll be at 46k miles at my next oil change. Is it time?😑
Patriot
Drives: 2019 Camaro 1SS 1LE Join Date: Sep 2020
I did. A better fluid makes a huge difference
2019 Camaro SS 1LE M6, Ported LT2 Manifold w/ 95mm TB, Flex fuel, Kooks Longtubes catless to NPP, Big Gulp intake, TSP EL-C7 cam w/ Titanium valves and dual Springs, 605HP at the tire N/A
![]() ![]() ![]() ![]() ![]() Drives: 2023 CT5 Blackwing, 2025 C8 Z07 Join Date: Sep 2016
https://www.tremec-store.com/collect...smission-fluid
https://www.camaro6.com/forums/showt...=492814&page=9
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 2025 Hysteria Purple C8 Z07 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: like an old lady Join Date: Jun 2012
i changed my trans fluid at 3k miles. and again at 15. i'm going to put it on the yearly fluid change interval the brake and dif fluid are on.
![]() ![]() ![]() Drives: 2016 SS Convertible Join Date: Sep 2016
I used the GM syncromesh called out in the owners manual changed at 2500 miles or there about. I figure better off using the spec fluid while it's under warranty. I used the same in my mangum which is the same trans - in my 71 Camaro. I will probably move both to either RP or the Tremec stuff next time and then keep that in stock for both cars.
![]() Drives: 2019 Camaro 2SS 10-speed Join Date: Aug 2018
Anyone run AMSOIL?
#7 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
I use Signature Multi-Vehicle ATF in mine. Works fine, it's slightly better at cold but not by too much.
Sent from toaster or something
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
#8 |
My dealer put a note in my last receipt when I got an oil change saying manual trans change recommended at 45k miles under severe conditions. I don't track mine but do slam it occaisonally if there is an opening with no traffic. Never slammed it above 4th gear as I would be deep into triple digits. Just no place in my area to do that. So not sure I come in the severe category. But I will change during my next oil change. I changed my rear fluid last time.
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
most day-to-day street driving counts as the "severe" category.
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
almost 30k still havent changed it yet gotta figure out what i want to use...
#11 | |
IYAOYAS
Drives: 22 1LE 2SS M6 Riverside Blue Join Date: Mar 2018
2022 Riverside Blue Camaro 2SS 1LE/ PDR
2020 Red Hot Camaro 2SS 1LE/PDR /Sold 2018 black Camaro 2SS M6 Redline Edition/Traded 2016 summit white Camaro RS V6 M6/Traded |
#12 |
USCG Retired (MKC)
Drives: 2018 2SS 1LE Black Join Date: Aug 2018
There are many 5+ page threads covering this topic, here is a sample.
https://www.camaro6.com/forums/showt...ansmission+oil https://www.camaro6.com/forums/showt...ansmission+oil |
#13 |
![]() ![]() ![]() ![]() Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
Changed mine at 20k. Helped with cold weather. To fill I bought a small electric pump and snaked a hose through the engine bay. Took longer to get the car up on 4 jack stands to get car level then to drain and fill.
#14 | |
