Old 01-24-2021, 05:31 PM   #1
MatthewAMEL
MatthewAMEL's Avatar
AFR for DI?
Greetings all.
Trying to do some learning.
Is 14.7 still the AFR target for DI engines?
~11.5 for WOT?
How about when using E60? or E85?
Are we all leaving AFR's behind in favor of Lambda?
If so, what EQ are we looking for in Lambda under WOT? With E85?
Thanks for any wisdom you can offer.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
2025 Hysteria Purple
C8 Z07
Old 01-24-2021, 06:11 PM   #2
Tschw
Drives: 16 HBM 2SS
1 lambda is always stoich no matter what fuel you’re using. PE is .85 to .9 on a NA DI motor.
Tschw is offline   Reply With Quote
Old 01-24-2021, 10:15 PM   #3
squish72
Drives: 2016 2SS 8AT
Lambda is easier to use as 1 is stoichiometric for whatever fuel source you are using. I think you can run a little bit richer PE with e85 but Im not positive. I wish I had e85 closer then 250 miles then I'd do more research. But I run PE around .87 to .88 on my car.
squish72 is offline   Reply With Quote
Old 01-26-2021, 08:11 AM   #4
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
As mention above, speaking in terms of Lambda for E85, Stoich is 1.0. WOT PE should be around .87 for a NA application. You would still target the same fueling even on E60. The Flex tune will adjust the stoich ratio and Stoich will remain 1.0 Lambda on your Wideband.
If you want to speak in terms of AFR then Stoich is around 14.1 for E10 93 and WOT PE I believe GM normally target's 12.6 which is a tad rich.
Ethanol allows the ability to run a little leaner due to being superior at cooling the combustion process and pulling heat out of the cylinder.
You never target 11.5 on a DI engine even with boost. DI stuff does not like running that rich.
KingLT1 is online now   Reply With Quote
Old 01-26-2021, 09:52 AM   #5
Choda
Drives: Turbo 6.2
I've saw a lot of shops target 12.2 for boosted DI setups
2016 Twin Turbo Camaro SS - 968hp/970tq 8.9@153
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100
Choda is offline   Reply With Quote
Old 01-26-2021, 11:39 PM   #6
KingLT1
KingLT1's Avatar
Agree with Choda...
Far as Forced Induction goes, I target .82 lambda on Ethanol. On pump 93 I would probably target a little richer. .80 lambda or 11.9-12.0 afr.
Old 01-27-2021, 11:16 AM   #7
MatthewAMEL
Thanks everyone for the replies. The numbers I was seeing seemed really lean to me, but I guess that is part of the DI world.
I now know I'm where I should be with my 12.8 AFR in 3rd WOT.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
C8 Z07
Old 07-15-2021, 10:59 PM   #8
yourmomshouse
Drives: 2016 2SS 6MT
Bumping this. so lambda on the gauge on E should be .87 at WOT?
yourmomshouse is offline   Reply With Quote
Old 07-16-2021, 05:58 AM   #9
laynlo15
Drives: 2022 Lt1 A10
I run mine about 12.8 to 13.0 on E85 and 14.5 is about right at idle.
Old 07-16-2021, 08:29 AM   #10
KingLT1
KingLT1's Avatar
Correct
