Old 01-23-2021, 11:07 PM   #1
Josedlc98
Drives: 6th gen camaro ss
Shift to park message
my car will not read park , but will read reverse, nuetral and drive ? has anyone else run into this problem ?
Josedlc98 is offline   Reply With Quote
Old 01-24-2021, 02:20 PM   #2
Aviadtz
Drives: 2017 Camaro 2SS 50th
Could be bad ground somewhere, I would look for any loose connections.
Might also try to disconnect the battery for around 10mins and then reconnect and see if it works.
Aviadtz is offline   Reply With Quote
Old 01-26-2021, 08:49 AM   #3
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
http://letmegooglethat.com/?q=shift+...+gen+Camaro+A8
Old 01-26-2021, 12:21 PM   #4
Umbriel
Drives: 2016 Camaro SS
If it is reading other spots just not park I would lean towards the switch in the shifter, it is a known issue.
Umbriel is offline   Reply With Quote
Old 02-01-2021, 04:57 PM   #5
Josedlc98
i bought a new shifter and it still says the same thing man
Old 02-01-2021, 05:06 PM   #6
Umbriel
Mine issue was a lose ground on the back of the driver's side head but we checked the linkage first, then replaced the shifter, then the fuse block on top of the battery and then the TCM. At that point we had to take to the dealer and they charged me almost $800 in labor to find the issue which just ended up being a lose ground om the head. The shifter is a known issue in a lot of GM vehicles and if that isn't the issue you might have to do like I did and let the dealer run it down.
Sent from my SM-N986U using Tapatalk
Old 02-01-2021, 05:10 PM   #7
Josedlc98
Do you know the location of the ground on the driver side head ?
Old 02-01-2021, 09:20 PM   #8
Umbriel
No sorry the dealer fixed it and just said it was on the back of the driver's side head.
Old 02-03-2021, 12:34 AM   #9
Josedlc98
i checked the driver side head ground and its tight man , idk wtf do
Old 02-03-2021, 05:49 AM   #10
dmcmahan60
dmcmahan60's Avatar
Drives: 2017 SS
https://www.camaro6.com/forums/showthread.php?t=553306
dmcmahan60 is offline   Reply With Quote
Old 02-03-2021, 08:29 PM   #11
Josedlc98
Originally Posted by dmcmahan60 View Post
that link doesnt bring up nothing
Old 02-03-2021, 10:02 PM   #12
Umbriel
Could be a lot of things causing it unfortunately, might just need the dealer to look at it like I ended up having to do.
Old 02-04-2021, 06:00 AM   #13
dmcmahan60
dmcmahan60's Avatar
Drives: 2017 SS
Try again, I fixed it.
Old 02-04-2021, 04:00 PM   #14
Josedlc98
I wonder if its the neutral switch , but i took it to the dealer ship already
