Old 01-22-2021, 04:52 PM   #1
NiteBlitz
Drives: Camaro ZL1
Where to place jack on rear of car
In my photo, circled in red. Is that where I can place the jack to lift car up. I want to lift rear end so I can swap drag radials with stock wheels. I got a headache from searching google for an answer and don’t want to mess things up.
NiteBlitz is offline   Reply With Quote
Old 01-22-2021, 04:55 PM   #2
Badmojo
aka BeastZL1
Badmojo's Avatar
No, jack it up on the black rear cross member (with the white peeling sticker). Make sure you don't clip the ears on the diff module behind the cross member.
2019 Camaro ZL1 1LE
Racing for ALS Youtube Link
Old 01-22-2021, 06:44 PM   #3
Vigilante375
Drives: 2018 Camaro ZL1
I jacked mine up there but used a thick piece of rubber as the point of contact. I then put jack stands on each side, since I have the mag pucks, and then rested it on those.
A small 2x4, cut to fit in the area, should work too.
Old 01-22-2021, 06:53 PM   #4
Bangkok_ZL1
Flying around Thailand
Bangkok_ZL1's Avatar
Drives: 2019 Camaro ZL1
What about the front side? Where to Jack it up high enough to fit jack stands
Bangkok_ZL1 is offline   Reply With Quote
Old 01-22-2021, 07:09 PM   #5
Vigilante375
Your jack may not have enough lift on them but look at this thread for info on this:
https://www.camaro6.com/forums/showthread.php?t=452280
Old 01-23-2021, 09:47 AM   #6
Bangkok_ZL1
Thank you. However, today I decided. I just said screw it and I'm buying the lift in a few weeks. It's only a little over a grand so. Then there be little need of a jack stand or jack stands
Old 01-23-2021, 01:37 PM   #7
sengli
sengli's Avatar
Drives: 2015commemorative vert 2SS
There are so many things under these cars that is kinda fragile. Plus I hate bending over anyway.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded
2015 commemorative vert 2ss
sengli is offline   Reply With Quote
Old 01-23-2021, 01:53 PM   #8
Alain
Alain's Avatar
I can't wait to have a garage big enough to install a lift !!
OP, if you're like me and don't have the ability to have a lift in your garage yet, look into quick jacks. You'll never have to worry about were to place jack stands ever again.
2018 ZL1 1LE/Red hot
Old 01-23-2021, 04:52 PM   #9
NiteBlitz
Drives: Camaro ZL1
Looks great but how do you change out the tires on that?
Old 01-23-2021, 04:53 PM   #10
NiteBlitz
Drives: Camaro ZL1
I just checked out their website briefly. Looks interesting, where to they grab on the bottom. Im assuming it doesn't destroy the side skirts.
Old 01-23-2021, 09:03 PM   #11
MatthewAMEL
MatthewAMEL's Avatar
That's a 'parking lift' not a working lift.
Gives you two parking spaces.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
2025 Hysteria Purple
C8 Z07
Old 01-23-2021, 09:14 PM   #12
20Bluezl1
This is great I was about to start a thread asking to see if the quick jack should extend forward like the manual says. Or I read that it should extend backwards so the weight of the front counter balances.
Old 01-23-2021, 09:33 PM   #13
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
You can easily change tires on a 4 post lift. I do it all the time on mine. I have a Jack that slides down the center track of the lift and has arms that are adjustable inside to outside. I can lift either the whole front end or the whole rear end off the car off the wheel paths. I also have a Jack tray that I can use and raise all 4 wheels off the lift at the same time.
It’s not just an extra parking space.
CW3SF is offline   Reply With Quote
Old 01-24-2021, 10:09 AM   #14
JG61354
JG61354's Avatar
Drives: 2019 ZL1 1LE Camaro A10
I took some roll cage tubing and welded it up. It sits about 3/4’s of an inch below the side skirt. On my ZLE when you use the front one it lifts front and rear off the ground. It’s been working really well for me, much easier when putting the track tires on.
2019 ZL1 1LE
2016 Mustang GT
2014 GT 500
2012 GT 500
2010 Mustang Spec Iron
2003 New Edge w/Coyote Now running in America Iron
2000 New Edge w/ Coyote
2004 Corvette
2002 Corvette
JG61354 is offline   Reply With Quote
