Old 01-22-2021, 11:11 AM   #1
JBinSD
Drives: '23 LT Vert M6'16 Hyper 2SS Vert MT
Problems with '17 and '18's or Just bad info in Consumer Reports?
Started shopping the used market for a convertible 2SS M6 only, and I saw the reviews in Consumer Reports really panning the '17 and '18's. I owned a '16 and loved it to death (I'm an idiot for selling). Was there really anything changed from '16--17 and 18? I know the 19's had the funky front end (subjective).
I'm also in the boat of loaded 16-18 vs. "stripped" 20 or 21. I normally prefer leather and liked the ventilated seat option, but really the V-8 is most important.
I know there are tons of threads on this, and I searched and read a bunch, but wanted input from the masses on:
1. Are there actually problems with the 2017/2018 SS's? (not the transmission, I'm an M6 dude)
2. Any significant motor or other changes from a 17 or 18 SS to a 20 or 21 LT1?
3. Young stripper or older lady with farkles?
The used marked currently has ridiculous prices, so I may wait a bit, but I have a Model 3 performance Tesla that will be declining in value if I wait too long. . .
JBinSD is offline   Reply With Quote
Old 01-22-2021, 11:18 AM   #2
ctrlz
I would trust what you read here more than CR.
I have a 2017 2SS M6. Only thing I was not happy with were the stock summer-only tires and semi-metallic brakes. Like many here, I changed these myself.
From what I see here, two recurring issues are A8 torque converter shudder (not an issue with a manual) and problems restarting the car when hot ("heat soak" issues). Personally, have never had the restart problem, and it does get pretty hot in south jersey in the summer. But I'll keep an eye on that.
Old 01-22-2021, 11:27 AM   #3
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
I'm not aware of any widespread issues with the stick shift SS cars. None to speak of with mine.
Mine did have a weird manufacturing "issue" where a wiring harness was routed too close to the AC belt. I had read about others experiencing a condition where that rubbed all the way through and started to impact engine performance. I checked mine when the car was brand new and determined it was routed incorrectly, so simply unplugged the connector, routed it right, and plugged it back in... now there is a ton of clearance in that area. Otherwise no issues at all in the last 4 years of ownership.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
Old 01-22-2021, 11:29 AM   #4
TP2SS
TP2SS's Avatar
Drives: 2016 2SS Convertible
The no-start hot-soak issue has been solved by a member here. Adding a second ground cable from the engine (two location options) to the NEG body ground lug adjacent to the engine bay fusebox has resolved the issue for multiple owners recently. The thread is here in the General section.
https://www.camaro6.com/forums/showthread.php?t=586153
Hyper Blue/Ash Gray
A8
Magnetic Ride Control
Dual Mode Exhaust
2019+ version Split Spoke Silver Wheels
Navigation
Silver Rally Stripes
TP2SS is offline   Reply With Quote
Old 01-22-2021, 11:31 AM   #5
JBinSD
Thanks guys, I find it interesting that a business like Consumer Reports would downgrade a model year when there were no obvious production changes, but wanted to make sure.
Since I"m looking for a convertible, I waited for winter, thinking I'd get a better deal, but there just aren't many verts with an M6 on the used market.
Old 01-22-2021, 11:31 AM   #6
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
The people with suspect cars are usually fairly loud, the ones with good cars are pretty quiet.
Old 01-22-2021, 12:03 PM   #7
ctrlz
I'm in that thread. Interesting problem and I am hopeful that the OP's solution finds long term success.
Old 01-22-2021, 12:09 PM   #8
Azerlazer26
Azerlazer26's Avatar
Drives: 2018 Camaro 2SS
16-18s have mostly remained the same. (With little bug fixes here and there) 2017 was the first year the tire temp status (cold *blue*/normal*green*) was introduced . 18 they added a low washer fluid sensor.
My car was an early 18 build so the dealer had to perform a minor TSB but for the most part she’s been a tank.
Azerlazer26 is offline   Reply With Quote
Old 01-22-2021, 12:23 PM   #9
mano_camaro
IYAOYAS
mano_camaro's Avatar
Drives: 22 1LE 2SS M6 Riverside Blue
I had a 18 2SS M6 also, and besides starting issues when hot, had suspension components come loose but they are easy DIY fixes for the most part, and some engine oil cooler line leaks.
2022 Riverside Blue Camaro 2SS 1LE/ PDR
2020 Red Hot Camaro 2SS 1LE/PDR /Sold
2018 black Camaro 2SS M6 Redline Edition/Traded
2016 summit white Camaro RS V6 M6/Traded
mano_camaro is offline   Reply With Quote
Old 01-22-2021, 12:30 PM   #10
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
I don’t ever read Consumer Reports because they seem to be biased to foreign vehicles over American. This my opinion only so take it with a grain of salt and the 2017s and 2018s are okay. My 2017 ZL1 was used when I bought it in 2019 and had all the TSBs done when I got it. Good luck in your searches.
Old 01-22-2021, 12:57 PM   #11
NotFast
Drives: 2021 LT1
Consumer Reports takes data from their subscribers. Most of the subscribers that respond to the survey are old - hence the good reviews of older cars with ancient infotainment systems.
I trust their info to some degree, but a Camaro and a Camry are totally different beasts.
NotFast is offline   Reply With Quote
Old 01-22-2021, 01:37 PM   #12
gtfoxy
Drives: '21 Wild Cherry ZL1
I noticed their rating back when I bought the SS.
I’ve traditionally ignored their ratings & this time was no different.
I remember way back in the late 80’s looking at Mustang ratings. The only thing I paid attention to was the statement “Gut wrenching acceleration.”
It made me actually a bit giddy remembering my first ride in a 89 GT when I was much younger.
Old 01-22-2021, 01:43 PM   #13
gpskinzhut
gpskinzhut's Avatar
Drives: 2020 Corvette Stingray Z51
I've had a pinion seal leak and the oil pan bolts are loose. She's been a rock otherwise.
2020 Corvette 2LT Z51
2017 ZL1 A10: (SOLD) ||
2017 2SS M6: (SOLD) || 2014 2LT Convertible: (SOLD) || 2010 2LT M6 Supercharged:(SOLD) || 1987 IROC-Z 5.0 M5: (SOLD)
gpskinzhut is offline   Reply With Quote
Old 01-22-2021, 01:56 PM   #14
JBinSD
Any opinions on year models from '16 to '21, V8 M6 Convertible?
If I went the '21 LT1, I would probably do Recaros NPP and tech, I think that is still under 1SS price, but over a "16-'18 loaded 2SS.
