Old 01-21-2021, 07:14 PM   #1
Ferociter
Drives: Camaro SS 1LE
HPDE without the front splitter on SS 1LE
I had two new front tires mounted and the tech crashed the splitter into a parking curb and crushed it. The bumper cover has minor damage. Both are being replaced by the Tire store at their cost, however, it won't be fixed before my track day at Sebring. My plan is to have them remove the damaged splitter and just go without it. Any major issues with that besides a little less downforce?
Ferociter is offline   Reply With Quote
Old 01-21-2021, 07:33 PM   #2
samr350
samr350's Avatar
Drives: 2017 SS 1LE
It wont cause any issues, and I'd be amazed if you noticed any handling difference.
samr350 is offline   Reply With Quote
Old 01-21-2021, 09:35 PM   #3
cdrptrks
cdrptrks's Avatar
FYI there are 4 rivets that have to be drilled out and it is a pain to remove all of the old adhesive.
Old 01-22-2021, 11:04 AM   #4
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
im sure you would be fine!
Old 01-22-2021, 12:19 PM   #5
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
This
Old Ride: 2016 Callaway SC630 Camaro SS
Old 01-22-2021, 06:21 PM   #6
Ferociter
Thanks guys - they removed the splitter in about 10 minutes. Not worried about the old adhesive as the entire bumper cover will be replaced as well.
Old 01-22-2021, 08:45 PM   #7
cdrptrks
cdrptrks's Avatar
Also you may want the replacement splitter to be aftermarket if you can find a thicker/stronger one.
Maybe you will notice a slight bit of understeer on track without it but I would not skip the event to wait for a new splitter.
https://www.camaro6.com/forums/showthread.php?t=516368
