Old 01-21-2021, 04:50 PM   #1
ChadSZL1
Red Bull
ChadSZL1's Avatar
Drives: 2017 Chevy ZL1
Exclamation Aero force interceptor gauge
Does the aero force interceptor gauge read ethanol content after activating it in the ecm? I looking at adding one so i can keep it at E60.
ChadSZL1 is offline   Reply With Quote
Old 01-21-2021, 05:01 PM   #2
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
I believe the Aeroforce gauge does have e content. Another option is the Fuel It Bluetooth module that plugs right into the ethanol sensor. I just put one on my car and works great. Can check e content on the app and it has a calculator to tell you how much e85 to mix.
https://lsa-conversion-store.myshopi...hanol-analyzer
CW3SF is offline   Reply With Quote
Old 01-21-2021, 08:02 PM   #3
ChadSZL1
Red Bull
ChadSZL1's Avatar
Awesome..... I looked at those also. I like the availability of monitoring a lot of other important info that’s why I like the gauge a little more. No one could answer for sure if it monitored ethanol so far.
Old 01-21-2021, 08:46 PM   #4
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Banks iDash can read E too FYI
Old 01-21-2021, 08:50 PM   #5
ChadSZL1
Red Bull
ChadSZL1's Avatar
Never looked at that but I will. Thanks
Old 01-21-2021, 10:25 PM   #6
dbs1
Drives: 2017 ZL1
Yes, aeroforce can show alcohol content.
Just don't go out boozing and have dps check that gauge!
dbs1 is offline   Reply With Quote
Old 01-22-2021, 11:40 AM   #7
ZLE dude
Drives: '18 ZL1 1LE
The Banks i-dash can monitor up to 8 data points at a time, including ethanol content(once you have a sensor installed and enabled). I'm quite happy with mine. You can adjust it to show I believe, 4-8 things at a time, along with alarm set points for each individual item shown (IE: mine lights up and starts flashing yellow if oil pressure is below 27psi)
2018 ZL1 1LE - Summit White, PDR, Rotofab CAI, 95mm TB, CSP 2" catless LT's, JMS Voltage Booster, AEM X-series WB, DSX flex fuel sensor, Banks Data Monster, Tuned by Ted Jannetty, 5% Tint, Blackvue DR900S-2CH, Diode Dynamics lighting, IGL Kenzo ceramic coating
ZLE dude is offline   Reply With Quote
Old 01-22-2021, 07:32 PM   #8
Bangkok_ZL1
Flying around Thailand
Bangkok_ZL1's Avatar
Drives: 2019 Camaro ZL1
Since you have pulled that pillar cover off before, Please enlighten me on the proper way to do this please. Thanks
Bangkok_ZL1 is offline   Reply With Quote
