Old 01-19-2021, 09:44 AM   #1
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
Struts ground, getting ready for the spring with 1LE spec Apex wheels
For the folk that have ground their struts down, does this look typical? I test fit a wheel on and there is a few mm of gap.
Old 01-19-2021, 04:00 PM   #2
AZ_1LE
Drives: 2019 ZL1 1LE
Yea that's what it looked like on mine with OEM 1LE wheels
Old: 2017 SS 1LE
Old: 2017 ZL1
Current: 2019 ZL1 1LE
AZ_1LE is offline   Reply With Quote
Old 01-19-2021, 05:47 PM   #3
TWG1
TWG1
Drives: 2019 Camaro ZLE
Looks about right. You don’t have to load suspension to check clearance. I found jacking it up and getting underneath from slightly behind the center of the wheel looking forward and up provided best view.
2019 ZLE M6
2019 ZL1 A10 (Sold)
1967 Jaguar XKE Series 1 Roadster
2021 F150 Powerboost (on order)
TWG1 is offline   Reply With Quote
Old 01-19-2021, 07:31 PM   #4
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
if you have pictures I'd like to compare. I went taller than needed definitely but not sure about depth, I bought the first 1/2 or so down to the same depth as the top was.
