Old 01-16-2021, 10:20 AM   #1
777
Drives: 2017 Camaro SS 1LE
LT2 intake high pitch noise
Hi guys. I installed my lt2 intake and 95mm throttle body and cannot figure out what is causing this extremely loud high pitch noise. If I change the throttle body out nothing changes. If I switch the lt1 intake back on it goes away. I’ll try and post a video of it.
777 is offline   Reply With Quote
Old 01-16-2021, 10:26 AM   #2
Puddin
Check for leaks at the brake booster fitting or gasket between the throttle body and manifold.
Old 01-16-2021, 10:29 AM   #3
777
I was thinking brake booster but tried to play with the hose and fitting thinking if it was loose it would change the noise but nothing happened. I have the ICT billet adapter for the throttle body which has the print gasket and paper gasket so I can’t imagine that being it either.
Old 01-16-2021, 10:46 AM   #4
777
Definitely not the brake booster fitting. I took the fitting out and plugged the hole. Noise still remains.
Old 01-16-2021, 12:18 PM   #5
777
Throttle body gasket. Not sure what was happening. I switched the direction of the gasket and tightened it as tight as I could get the adapter and now no more noise. Thanks
Old 01-16-2021, 01:13 PM   #6
Puddin
Good deal I figured it had to be one of the two.
Old 01-16-2021, 02:16 PM   #7
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
Good to know. Was it the smooth or rough side of the gasket towards the throttle body.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 01-16-2021, 04:58 PM   #8
777
I don’t really remember. It still has a very slight leak but the loud noise is gone. I’m going to get some RTV and put it on the paper gasket and see if that clears everything up. The RPMs will hang around 2000 if I give it a small rev so im assuming it’s a vacuum leak from that.
Old 01-16-2021, 05:15 PM   #9
BlackbeastSS2
I am going to do the exact same once I am ready to tighten it up after adding a few more mods.. RTV is the way to go because of porting the opening for the 95mn it’s missing that O ring part of the gasket.
