Old 01-16-2021, 08:20 AM   #1
FarmerFran
FarmerFran's Avatar
Car Weight - 2020 2SS Vert
Only options
Metallic wheels
Black wheel lugs
NPP
Weight = 3945 (including all fluids)
Sheesh. I thought my GTO was heavy
Old 01-16-2021, 08:24 AM   #2
Drags1998
Drives: 15 SilveradoLTZ,162SSVert BlazerRS
Just think how FAST it would be at 3K pounds!!!!!
Drags1998 is offline   Reply With Quote
Old 01-16-2021, 08:29 AM   #3
JSH
JSH's Avatar
Drives: '20 ZLE
My coupe weighs ~3600
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO.
15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR.
100 octane: 1045hp/1055tq.
100 octane + Alky MAF Meth (1) 10+:
Old 01-16-2021, 08:39 AM   #4
HCI2000SS
HCI2000SS's Avatar
Drives: 2018 Camaro V6/RS
On a certified CAT scale my 2018 RS V6 coup weighed 3380 lbs with a half tank of fuel. What year GTO? My buddy had a 2006 and it was just shy of 3800 IIRC
HCI2000SS is offline   Reply With Quote
Old 01-16-2021, 08:44 AM   #5
JSH
JSH's Avatar
Drives: '20 ZLE
This is the only GTO I've ever owned but it weighed on 2450 with 1750hp
Only options
Metallic wheels
Black wheel lugs
NPP
2020 ZL1LE A10.
Old 01-16-2021, 08:51 AM   #6
FarmerFran
FarmerFran's Avatar
2004 and mine weighed just over 3820.
Old 01-16-2021, 08:52 AM   #7
FarmerFran
FarmerFran's Avatar
Unless you did any weight reduction it is right on the door jamb. well not including anything you put in the car.
Old 01-16-2021, 09:01 AM   #8
FarmerFran
FarmerFran's Avatar
Now pull the number off the door and see how close it is.
Old 01-16-2021, 10:34 AM   #9
cthompson07
Drives: 2016 hyper blue 2ss
The door jam shows gross weight rating, which is the maximum weight rating with full fluids and passengers, not curb weight.
2016 HBM 2ss m6 with MRC and NPP
1992 mr2 turbo m5
cthompson07 is offline   Reply With Quote
Old 01-16-2021, 10:49 AM   #10
Yep, unless Hennessey worked some weight reduction magic such as removing seats or replacing body parts with carbon fiber equivalents, I simply don't see how this is possible. They must have added a bigger S/C with auxiliary components such as an intercooler, a pump and a bunch of extra pipes. I'm not even sure JSH has a different, less heavy exhaust, he says stock catback in his sig.
Old 01-16-2021, 10:49 AM   #11
s346k
s346k's Avatar
Drives: like an old lady
Only options
Metallic wheels
Black wheel lugs
NPP
my 1ss 1LE weighed 3720 bone stock.
Old 01-16-2021, 10:57 AM   #12
Z28James
Z28James's Avatar
Drives: 2021 Camaro 2SS; 2022 Bolt
its those black lug nuts weighing you down....
Z28James is offline   Reply With Quote
Old 01-16-2021, 11:06 AM   #13
Scottyz
2019 ZL1 1LE MY GOON
Scottyz's Avatar
Drives: 1980 Z28 Big Red.
ZL1 1LE = 3858 lbs roughly but close
Old 01-16-2021, 11:35 AM   #14
FarmerFran
FarmerFran's Avatar
The door jam shows you 2 things
1. The GVWR = the total weight the car can carry including passengers and items you put in the car. This number includes all fluids.
2. The max weight of occupants and cargo
Subtract 2 from 1 and that is the weight of your vehicle
