![]() Drives: 2018 ZL1 Garnet Red Join Date: Nov 2009
2018 ZL1
Just got my 2018 ZL1 in Garnet red with only 3300 miles on her. Will the pilot sport all season tires 285/30/20, 305/30/20 fit? They are the same size as the factory tires just all season? The reason I ask is that when doing a search these tires come up as not fitting a 2018 ZL1?
Bone stock
![]() Drives: 98 Z28 SS, 2018 ZL1 HYPER BLUE Join Date: Aug 2008
Just go onto tire rack.com. They can confirm.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
Yes they should fit your ZL1 if they are the OEM size. Congratulations on scoring a lower mileage 2018 ZL1! Enjoy the new hotrod.��
![]() Drives: 2017 ZL1 Vert M6 Join Date: Feb 2019
Sure - by definition, if the tire size matches stock - which those do - it doesn't matter if they are summer, all season, studded snow, or slicks. The correct size is the correct size - width (285 or 305), aspect ratio (30), wheel diameter (20").
Thanks guys
Bone stock
