Old 01-15-2021, 08:45 AM   #1
sspddmn
sspddmn's Avatar
Drives: 2018 ZL1 1LE and 1991 Z28
Boost?
So I installed some aeroforce guages yesterday and the boost is reading at -22.7 at idle. Is this correct? I read that stock boost is in the 9's. My car is completely stock except for rotofab and catback exhaust. TIA.
In the garage: 2018 HBM ZL1 1LE // 2013 ZL1 (sold) // 1991 Camaro Z28 5.7L // 2022 Audi E-tron SUV (wife's car) // 2002 Camaro SS (sold)
sspddmn is offline   Reply With Quote
Old 01-15-2021, 08:57 AM   #2
Z OH 6
Drives: 2024 CT5-V Blackwing
Engine has vacuum at idle.
Old 01-15-2021, 09:04 AM   #3
swisstyphoon
Former GM Technician
swisstyphoon's Avatar
Drives: 2018 ZL1 A10, 06 Silverado Duramax
Sounds about right.
Where did you find this gauge with the ZL1 logo on it?
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, DSX dual intank pump, Lingenfelter high flow check valve, Motion Raceworks Flex Fuel adapter, LPE Big Bore Hpfp, XDI 30% Injectors, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can.
2006 Silverado Duramax Diesel
MPI Compound Turbo
40% over Injectors
Efi Live DSP5 Tuning
Follow me on Instagram: SwissZL1
swisstyphoon is offline   Reply With Quote
Old 01-15-2021, 09:05 AM   #4
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
yes, that reading is normal. Look at your stock gauge and notice the needle is in vacuum (negative) at idle
Old 01-15-2021, 09:17 AM   #5
IneedAZ
IneedAZ's Avatar
It is available from the Aeroforce website. I have the same one.
Old 01-15-2021, 10:21 AM   #6
sspddmn
sspddmn's Avatar
Ah ok. Thanks guys. Was starting to get worried.
Old 01-15-2021, 10:39 AM   #7
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
Sounds normal (in vacuum). Where did you tap into 12v keyed on power?
CW3SF is offline   Reply With Quote
Old 01-15-2021, 10:50 AM   #8
swisstyphoon
Cool, thanks.
I have the P3, thinking about switching to the Aeroforce.
2018 Camaro ZL1 A10
MPI Compound Turbo
40% over Injectors
Old 01-15-2021, 11:40 AM   #9
7LitreC5
Drives: 18 Tahoe RST, 19 Z06
Cool, thanks.
The Banks iDash is worth considering as well. I switched from a P3 to the iDash and really like it.
7LitreC5 is offline   Reply With Quote
Old 01-15-2021, 11:50 AM   #10
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
No worries on your boost reading. Mine runs in the negative part of the gauge most of the time until I’m driving fast or stomping on the accelerator.
Old 01-15-2021, 11:54 AM   #11
JSH
JSH's Avatar
Drives: '20 ZLE
Yea, you should read negative boost or vacuum as you drive around town. If you can read the boost gauge, which I dislike, it should get to 9# at WOT.
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 01-15-2021, 12:42 PM   #12
sspddmn
sspddmn's Avatar
The aero force gauges plugs directly into the obd. Zip tied excess wires, and tucked the rest leading down to the obd.
Old 01-15-2021, 12:45 PM   #13
sspddmn
sspddmn's Avatar
Yep only think I dislike about these guages is that they are hard to read. Polarized sunglasses don't help either. I shoulda bought the p3 but these were from my 5th gen zl1. One of the guage led went out and finally got it fixed so now reusing them on my zle. Maybe in the future ill upgrade them to the p3
Old 01-15-2021, 06:12 PM   #14
LT4Greg
LT4Greg's Avatar
Yeah I think I did notice that a couple of times when I punched it! The throttle response is so much better though since I installed the Roto-Fab.
