Old 01-14-2021, 01:37 PM   #1
Snowwolfe
Drives: CTV5 V Blackwing on order
Shut down?
Up till today when I parked would hit the engine start/stop button and engine would shut down and radio would go off when I opened the door.
Now the radio continues to play for a few minutes.
Suggestions are appreciated
2022 CT5 V Blackwing with A10
2021 GMC Denali pickup with 6.2 and A10
2017 Ford Expedition
Snowwolfe is offline   Reply With Quote
Old 01-14-2021, 01:38 PM   #2
BBQdDude
BBQdDude's Avatar
Drives: 2010 Chevy Camaro 2SS RS
there is a software update. Check out the sub forum above this one.
BBQdDude is offline   Reply With Quote
Old 01-14-2021, 01:39 PM   #3
BBQdDude
BBQdDude's Avatar
https://www.camaro6.com/forums/showthread.php?t=587024
Old 01-14-2021, 01:59 PM   #4
Snowwolfe
Thank you. At least I know it’s not just my car
Old 01-14-2021, 02:21 PM   #5
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
Yep, had this happen to my 2020 Acadia I bought in Oct. Finally pressed 'Update' and let it do it's thing. Went back to normal, whatever that is.
Old 01-14-2021, 04:08 PM   #6
Snowwolfe
After a 40 mile ride today pulled into the garage and the update popped up on the screen. It did its thing so will see what happens next time I drive it.
Old 01-15-2021, 07:45 AM   #7
Cam-Aero
Drives: Camaro ZL1 1LE
Same thing happened to mine earlier this week. I was perplexed, until I got the software update message. I parked it, followed the instructions and let it do its thing. About 10 minutes later it was back to normal.
Good luck.
Cam-Aero is offline   Reply With Quote
Old 01-15-2021, 09:18 AM   #8
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
Does the car need to be running, or can I just hit the start button without starting the engine?
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
zx9rmal is offline   Reply With Quote
Old 01-15-2021, 09:23 AM   #9
Cam-Aero
Engine was off. I left it unlocked in the driveway, so I could get back in - just in case there were issues.
Old 01-15-2021, 08:13 PM   #10
Snowwolfe
Mine was parked in the garage and I had just turned off the engine then the update started. Not sure if it helped but I kept the garage door open till it was finished.
