Old 01-14-2021, 07:36 AM   #1
ZLAV1N
Previously CS10SS
ZLAV1N's Avatar
Drives: 2017 ZL1 A10
2" Kooks LT Headers, No Cats, Borla Atak Exhaust - Sound Clip Request
Does anyone have a sound clip of a set-up similar or equal to this?
2" Kooks LT Headers, No Primary or Secondary Cats, Borla Atak Exhaust
Will this be unbearably loud with NPP Open? Thoughts on Start Up Sound Level?
Trying to get the exhaust system dialed in before I have the entire system ceramic coated during the build.
Thank You
'02 Trans AM - sold
'05 SRT4 - sold
'05 STI - sold
'96 300ZX - sold
'10 2SS/RS M6 455rwhp - sold
'13 ZL1 M6 720rwhp - sold
'17 ZL1 A10 930rwhp - Katech Built
ZLAV1N is offline   Reply With Quote
Old 01-14-2021, 07:39 AM   #2
Z OH 6
Drives: 2024 CT5-V Blackwing
Yes, unbearably loud.
Old 01-14-2021, 07:46 AM   #3
ZLE dude
Drives: '18 ZL1 1LE
I'm sure if someone has this setup, you just need to step outside early in the morning and you'd hear them start it no matter where you/they live. That will be VERY loud. So if you want LOUD, this should do it.
2018 ZL1 1LE - Summit White, PDR, Rotofab CAI, 95mm TB, CSP 2" catless LT's, JMS Voltage Booster, AEM X-series WB, DSX flex fuel sensor, Banks Data Monster, Tuned by Ted Jannetty, 5% Tint, Blackvue DR900S-2CH, Diode Dynamics lighting, IGL Kenzo ceramic coating
ZLE dude is offline   Reply With Quote
Old 01-14-2021, 07:51 AM   #4
ZLAV1N
Previously CS10SS
ZLAV1N's Avatar
well sh!t, this is what I was afraid of.... any recommendations to quiet her down a little but still allow for ample air flow & most HP? Green Cats? Different Axel Back Exhaust?
'02 Trans AM - sold
'05 SRT4 - sold
'05 STI - sold
'96 300ZX - sold
Old 01-14-2021, 07:54 AM   #5
ZLAV1N
Previously CS10SS
ZLAV1N's Avatar
I am OK with loud but not LOUD. My 2013 ZL1 was 2" Headers with straight connection pipes to the stock axel back.... and that was LOUD as hell. I assume this would be close?
'02 Trans AM - sold
'05 SRT4 - sold
'05 STI - sold
'96 300ZX - sold
Old 01-14-2021, 08:08 AM   #6
Z OH 6
Green cats and a different catback will help a lot. The fact is, these cars get super loud with headers and removal of the primary cats.
Old 01-14-2021, 08:41 AM   #7
IneedAZ
IneedAZ's Avatar
So True...i have ARH 2" into ARH long system, but stock muffler. Cruising and idle not bad..Give it some throttle and very loud. I now keep it in sport for exhaust. I may have to go down from there.
Old 01-14-2021, 09:09 AM   #8
ZLAV1N
Previously CS10SS
ZLAV1N's Avatar
Is there a risk to running green cats on road courses & melting them? Or am I thinking of something else? Would the green cats decrease the HP a measurable amount, or just simply help quiet her down?
'02 Trans AM - sold
'05 SRT4 - sold
'05 STI - sold
'96 300ZX - sold
Old 01-14-2021, 10:11 AM   #9
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Thank You
No cats and the ATAK is going to be pretty much like open pipes, i had this and had to remove the atak mufflers. Its going to be VERY loud. I put on kooks green cats, with borla s-type and its still very loud, but not obnoxious. If you dont want cats you can use the borla resonators which will calm it down a bit. May want to change from the atak mufflers as well.
Old 01-14-2021, 10:27 AM   #10
ZLAV1N
Previously CS10SS
ZLAV1N's Avatar
Thanks for the information. This confirms my concerns. Do you have headers on your ZL1?
'02 Trans AM - sold
'05 SRT4 - sold
'05 STI - sold
'96 300ZX - sold
Old 01-14-2021, 10:52 AM   #11
ZLAV1N
Previously CS10SS
ZLAV1N's Avatar
Follow Up Question.... Would AWE Touring Edition Axle-back Exhaust fit with the Borla Atak piping that is already installed? If I just wanted to remove the Borla Atak Axle Back Mufflers and install the AWE Axle-Back? I assume so but I don't want to go the "cheap/risky" route, I would want to make sure the system is solid and matches up well.
I am sure this would still be loud but not as loud as the Atak, right? Or would the difference be negligible due to no cats & headers?
So... Kooks LT 2" Headers, No cats, existing Borla Piping to AWE Touring Axle-Back? Is this ok to do or not recommended?
Regardless.... I am leaning towards No Cats/No Kooks Green Cats so not sure what would keep her as "quiet" as possible.
'02 Trans AM - sold
'05 SRT4 - sold
'05 STI - sold
'96 300ZX - sold
Old 01-14-2021, 11:04 AM   #12
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Yes kooks 2"
Old 01-14-2021, 11:10 AM   #13
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
This im not sure. The ATAK is 3", im not sure if all cat backs are the same design. I dont know the size of the muffler inlet on the AWE, and it would need to be same design axle back.
You could add the borla resonators up front, the magnaflow 3" where x-pipe is or change mufflers. This all depends on how loud you want.
IMO headers with kooks/gesi green cats and borla s-type is one of the best sounding tone wise and decibel wise.
Old 01-14-2021, 11:19 AM   #14
ZLAV1N
Previously CS10SS
ZLAV1N's Avatar
Thank You. I appreciate you sharing your information & thoughts.
'02 Trans AM - sold
'05 SRT4 - sold
'05 STI - sold
'96 300ZX - sold
