Old 01-12-2021, 09:00 PM   #1
Crushed 1LE
Crushed 1LE's Avatar
Drives: 2022 ZL1 1LE
Track accessories really needed?
This will be my 1st year heading to my local road course. Was digging through some bits and pieces and found the GM Camaro track deflector package.
Is this stuff really necessary? It looks like a pain in the ass as the instructions required that these bits be removed for street use. That being said, why did they go to all the engineering and documentation if this was not a valid requirement for track use?
What's the consensus?
Crushed 1LE is offline   Reply With Quote
Old 01-12-2021, 09:04 PM   #2
suzbndt
suzbndt's Avatar
Drives: 2010 Camaro SS 2011 Mustang GT
My car came with them. They wouldn't have designed a solution for a non issue
Sent from my SM-N960U using Tapatalk
suzbndt is offline   Reply With Quote
Old 01-12-2021, 10:19 PM   #3
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
They don't need to be removed off track, I installed mine and left them on. There have been issues with power steering overheat so they seem like a good upgrade.
The parts you remove may provide a little more noise insulation and that's it.
SFV1LE is offline   Reply With Quote
Old 01-13-2021, 12:20 AM   #4
R3ctivision
1LE Convert
R3ctivision's Avatar
Drives: 2018 ZLE
I've never seen this kit before. Can someone post pics showing them on the car? They are for power steering cooling?
2016 Porsche 911 GTS (Racing Yellow)
2002 BMW Spec E46 race car (Lizard Green)
Previous cars:
- 2018 Camaro ZL1 1LE (Red Hot)
- 2018 Miata RF GT (Machine Gray/Auburn)
- 2017 Camaro 1SS 1LE (Summit White)
- 2008 BMW 135i (Montego Blue)
- 1996 BMW 328i (Arctic Silver)
R3ctivision is offline   Reply With Quote
Old 01-13-2021, 12:21 AM   #5
Pcormier66
Pcormier66's Avatar
Drives: 2019 ZLE
GM probably didn't perform exhaustive testing with the track deflector kit to determine the effects of increased water intrusion. That's my guess why they suggest to swap them back to stock for the street. But like SFV1LE I left mine on. Maybe I'm lazy but I can see the harm. Same for the hood vent. Take it off and put it on the shelf. At least for me here in TX.
Pcormier66 is offline   Reply With Quote
Old 01-13-2021, 12:22 AM   #6
Pcormier66
Pcormier66's Avatar
Drives: 2019 ZLE
Can't see the harm
Old 01-13-2021, 07:21 AM   #7
PROMETHEUS
PROMETHEUS's Avatar
I installed mine and left them on!
Old 01-13-2021, 09:16 AM   #8
Vigilante375
Drives: 2018 Camaro ZL1
If those are what I think they are, then they are air deflectors that will divert air to certain components (brakes or transmission) and help those components stay cooler.
I think the only reason why you would take them off for the streets is for the uncertainty of the roads we drive on daily and breaking them.
Old 01-13-2021, 09:50 AM   #9
clg82
Drives: 2020 Camaro ZL1
My ZL1 didn't come with these...are these a separate option?
Old 01-13-2021, 10:52 AM   #10
Pcormier66
Pcormier66's Avatar
Drives: 2019 ZLE
The kit the OP asked about is for power steering cooling and those components are flush to the underbody. The ZL1 brake cooling diverters are also flush to the control arm. The much bigger SS brake cooling diverters, which many ZL1 owners install, do hang down and mine regularly hit objects, but it's a flexible plastic panel and it simply deflects. Mine have some scratches on them but otherwise in perfect working condition. And if I do break one, the kit from GM is about $40.
Old 01-13-2021, 11:32 AM   #11
MatthewAMEL
MatthewAMEL's Avatar
If you have a SS 1LE, ZL1 or ZLE, you don't need the SS deflectors. The models mentioned already have deflectors installed. They also have larger brakes that have different cooling requirements.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
2025 Hysteria Purple
C8 Z07
Old 01-13-2021, 12:02 PM   #12
clg82
So why are people with ZL1s installing these then?
Old 01-13-2021, 12:09 PM   #13
beemer105
Drives: Chevrolet Camaro ZL1 1LE
This kit started coming with ZL1's and ZLE's sometime in 2019 model year.
From previous posts it doesn't seem like early production 2019 year cars came with the kit.
Plus several ZLE's came with gloss rocker panels instead of matte.
beemer105 is offline   Reply With Quote
Old 01-13-2021, 12:19 PM   #14
Snakebt6
Drives: Rally Green 2020 ZL1 1LE A10
Left mine installed..
I also removed the air deflectors under the front splitter as well as the one at the hood.
I dont do much driving in the rain so I im personally not too worried about it.
Dont forget DOT 4 for your brakes..15 50 oil and 140lbs of torque for the lugs.
Have fun!
Snakebt6 is offline   Reply With Quote
