Old 01-06-2021, 05:00 PM   #1
sspddmn
sspddmn's Avatar
Drives: 2018 ZL1 1LE and 1991 Z28
No Lift Shift
Happy New Year everyone. Just want to know how to engage the no lift shift (NLS) for our ZL1/ZLE's. I've watched a couple YouTube videos but they don't indicate how to engage it. The video I watched made it seemed like NLS is always on and happens only during a sweet spot between 5k rpm and 6k rpm. Is this true? If not please school me. TIA
In the garage: 2018 HBM ZL1 1LE // 2013 ZL1 (sold) // 1991 Camaro Z28 5.7L // 2022 Audi E-tron SUV (wife's car) // 2002 Camaro SS (sold)
sspddmn is offline   Reply With Quote
Old 01-06-2021, 05:50 PM   #2
Scottyz
2019 ZL1 1LE MY GOON
Scottyz's Avatar
Drives: 1980 Z28 Big Red.
Yes it’s true. There is nothing you set or press.
Old 01-06-2021, 06:04 PM   #3
Happy New Year
Here are some juicy details, enjoy: https://www.camaro6.com/forums/showthread.php?t=513327
Old 01-06-2021, 08:17 PM   #4
PROMETHEUS
PROMETHEUS's Avatar
Nothing to change, press or modify. WOT, 5000RPM. Keep it at WOT, don't come off the throttle. Engage clutch and shift! It takes some getting use to! Haven't master it myself yet, but dam it is a rush! Used on my last two track days.
Old 01-06-2021, 11:27 PM   #5
Nightfall ss1le
Nightfall ss1le's Avatar
Drives: 2020 A10 ZL1 1LE
You don’t need to be between 5-6K RPMs. You just need to be above 5K
2020 ZLE Roto-Fab dry
2018 Camaro 2SS 1LE - 2" TSP catless headers, Pray Ported stock IM/TB, Rotofab dry, DSX FF kit, dyno tuned by Pray. SOLD
Nightfall ss1le is offline   Reply With Quote
Old 01-07-2021, 02:16 PM   #6
sspddmn
sspddmn's Avatar
Completely different from my 5th gen zl1 then. Ok thanks everyone!
Old 01-07-2021, 06:24 PM   #7
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
I can’t seem to get the knack of it! I have driving a manual about 40 years now and I still let up on the accelerator when shifting thru the gears.
Old 01-07-2021, 07:51 PM   #8
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
I made a video using it on track, not sure if that helps anyone. You also can't be touching the brake pedal at all.
Old 01-07-2021, 07:57 PM   #9
JT Camaro
JT Camaro's Avatar
Drives: 2018 ZLE
Originally Posted by carguy55 View Post
I made a video using it on track, not sure if that helps anyone. You also can't be touching the clutch pedal at all.
brake?
JT Camaro is offline   Reply With Quote
Old 01-09-2021, 06:35 PM   #10
carguy55
carguy55's Avatar
=JT Camaro\brake?
Fixed it, thanks
Mods: MSD, Headers, 95mm TB, high flow cats, full 3" exhaust, SPL, MCS 2-way remotes, sway bars, rear diff lock outs, Sparco racing seats, 6 point harness, CMS roll bar, Nine lives wing, 6" splitter, ACS canards.
www.youtube.com/@Racer_Mike87
Old 01-10-2021, 01:30 PM   #11
JT Camaro
JT Camaro's Avatar
Drives: 2018 ZLE
Fixed it, thanks
just checking
Old 01-11-2021, 05:24 AM   #12
Bangkok_ZL1
Flying around Thailand
Bangkok_ZL1's Avatar
Drives: 2019 Camaro ZL1
When I had a manual, which was always up until my A10, I never took my foot off the accelerator EVER, not even 1st to 2nd. If tires spin, then adjust the set up. Don't shift late, and more importantly don't miss the shift/gear. It's so important having a good smooth shifter in easy gates. I wonder how the M6 feels. I miss the manual at times for sure. But this A10 is crazy... the paddles are almost freak'in useless, LOL.
Bangkok_ZL1 is offline   Reply With Quote
Old 01-11-2021, 03:24 PM   #13
Robster
Robster's Avatar
Drives: 2017 Camaro ZL1, 6M
I had the same issue, been driving stick forever. I had to literally lock my right knee and stand on the pedal to prevent my reflex of lifting. It's a hoot once you get it!
Robster is offline   Reply With Quote
