Old 01-03-2021, 09:09 AM   #1
Brettc83
Drives: 2018 Camaro 1ss
PCV delete?
Anyone deleting pcv system on an n/a LT1? Just venting the valve covers externally (to a vented catch can) and capping off valley port and intake port?
Technically it shouldn't be allowing unmetered air in because it is no longer a closed system with intake vacuum evacuating the crankcase pressure. I've seen high ram pictures with the valley port plugged so figured someone here has done something like this.
Should solve any chance whatsoever of oil/acids re-entering the engine and stays in a catch can instead. But I do understand vacuum in crankcase is a good thing for ring seal. Any issues seen without that vacuum on factory low tension rings?
Brettc83 is offline   Reply With Quote
Old 01-05-2021, 08:00 PM   #2
Brettc83
Guess not lol
Old 01-05-2021, 08:12 PM   #3
95 imp
Dumb Ass Deluxe
I am thinking about doing the same thing thing... I haven't got under the hood to test it all though.
Old 01-05-2021, 08:14 PM   #4
Brettc83
Should work. No different than old school valve cover breathers. Just losing the crankcase vacuum. Only part I'm not sure about
Old 01-06-2021, 03:37 AM   #5
95 imp
Dumb Ass Deluxe
Should, It works just fine on my 05 Dmax. They have a similar problem of coking valves since they are DI too.
I just do not know if GM came up with some sort of monitoring system for it now.
Old 01-09-2021, 04:50 PM   #6
Brettc83
Guess there's only one way to find out! Was hoping someone would have some input, especially on crankcase vacuum
