![]() ![]() Drives: 2017 ZL1 Join Date: Jan 2017
Alignment and possibly tire installation in Northern Nj
Looking for a place capable/comfortable of doing a full alignment on my car this spring. Also looking for some place that is able to mount w/o scratching 345/30R19 on 12" wide wheels.
Needs to be located in NNJ, suggestions?
#2 | |
![]() ![]() ![]() Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
I always pass by this shop and has high-end cars parked outside with race numbers and slicks. I haven't reached out yet but I will probably give them a call and feel them out. https://apexautowerks.com/pages/alig...-tire-services |
I gave them a call and will likely be doing business with them.
Who Needs to KNOW?
AZP Installs in Kenilworth does my alignments and tires.
A bit farther north, SJF Performance in Oak Ridge is another solid choice. As result, both extremely busy - call ahead.
#6 | |
If things go as planned I will be buying tires from them, getting them mounted/balanced, and the alignment done. They discussed going beyond just factory values and come up with a setup based on my usage in conversation. I have some complaints with swinging to the right under WOT that they'd approach. I have already relocated the harness in the rear drivers side and flattened out the material. I still have to notch the MRC up front.
#7 | |
Sounds great like I said tbey deal with alot of track setup cars. I will be taking my car there also after my suspension mods. Looking into getting camber plates also. |
#8 |
What plates?
#9 |
#10 | |
Jason McDaniel
Drives: Racecar Join Date: Jul 2014
I've spoken to them and sold them parts. Seem really knowledgeable and they service the local track guys well. |
#11 |
![]() Drives: 2018 SS 1LE Join Date: Jul 2018
As far as alignments I can’t recommend “Ivan’s alignments” more. He does amazing work, located in cliffsidepark
#12 | |
![]() Drives: '17 SS 1LE Join Date: Jun 2017
He will set your car up exactly based on what your goals are and knows what he's doing. |
#13 |
Got my wheels mounted/balanced at Apex Autowerks. No issues, turned out great. No scratches, they used black wheel weights to match the wheels, and were ready when I showed up.
I put them on the car today, now I just need it to warm up so I can take it back to them for an alignment.
#14 | |
