Old 12-31-2020, 02:13 PM   #1
19 2SS
Drives: 2019 camaro 2ss
Anyone know the difference between the two?
So a forum member was nice enough to send me a rotofab cai (not a big gulp) off his zl1, does anyone know the difference between the ss rotofab and zl1 rotofab? I emailed rotofab and they said it wouldn't fit but I cant tell the difference between the two
2.9 Whipple, CSP longtubes, borla atak, lt4 fueling, dsx aux pump, big gulp, nw 103mm, zl1 rep wheels, Toyo r888r
19 2SS is offline   Reply With Quote
Old 12-31-2020, 05:43 PM   #2
JT Camaro
JT Camaro's Avatar
Drives: 2018 ZLE
elbow bends are different as TB locations are different
If you need someone to take that Rotofab off you and put it to good use, I might know a guy
JT Camaro is offline   Reply With Quote
Old 01-01-2021, 06:46 AM   #3
wnta1ss
Drives: 2017 Camaro 1SS
Between stock LT1 and stock LT4 this is true, BUT, the OP has a Whipple supercharger on his LT1 (per his sig line), meaning that his TB has been moved to a location more like the ZL1. So, I'd consider a test-fit before giving up in this particular case.
Old 01-01-2021, 07:52 AM   #4
L78toLT1
L78toLT1's Avatar
The hood/front fascia differences may be problematic also.
Baby Blue
Old 01-04-2021, 11:38 AM   #5
RobbyBeefcake87
RobbyBeefcake87's Avatar
Drives: 2018 Camaro SS 1LE
Maybe the hood seal, which I doubt would be too big of a deal, but why would the front fascia be an issue? The air inlet is the same as an ss's behind the driver headlight.
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler.
2018 Colorado zr2 - zr2 sport bar, showcase spare tire.
2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace.
2017 Corvette Grandsport (sold) - untouched.
2006 GTO (sold) - iat relocation, air box mod, monero side marker lights.
RobbyBeefcake87 is offline   Reply With Quote
Old 01-06-2021, 08:38 AM   #6
L78toLT1
L78toLT1's Avatar
You're probably correct about the hood seal being the only issue.
Baby Blue
Old 01-06-2021, 09:02 AM   #7
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
It should work since you have a Whipple.
