Old 12-31-2020, 12:29 PM   #1
Mark R
Drives: 2018 ZL-1
Air Box Screws - A Decent Substitute?
I find it difficult to remove some of the 5 air box screws that hold the air filter in place because of the angle, and the screwdriver sometimes slips a bit when unscrewing them. Thus the heads are slightly mangled. I thought I would just get another set, but the dealer priced them at $18 each!
I can't even find them on GM parts sites.
Does anyone know of a decent substitute for these screws, maybe with an allen head instead?
Thanks for your help.
Mark R.
Albuquerque, NM
Old 12-31-2020, 02:02 PM   #2
hawk02
Coupe Newbie
hawk02's Avatar
I don't have any suggestions for substitute screws. However, when I need to remove the top of my airbox, I use this long neck Phillips screwdriver I bought at Lowes. Really helps to get that back corner screw out and in.
Old 12-31-2020, 02:08 PM   #3
Mark R
Drives: 2018 ZL-1
I should get one of those.
Old 12-31-2020, 09:13 PM   #4
Jaxcam02
Jaxcam02's Avatar
Drives: 2017 Silverado/2017 ZL1
It may be easier just to take the whole damn box out to get that last screw lol
Jaxcam02 is offline   Reply With Quote
Old 12-31-2020, 09:30 PM   #5
Mark R
Drives: 2018 ZL-1
This is the only vehicle I own that does not have tool-less air filter access.
Old 12-31-2020, 09:32 PM   #6
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
long shank phillips screwdriver works best. If you do remove the whole box (pull straight up and it will pop out of the grommets) watch the rubber grommets (3) as they can stick on the plastic dowels or fall out completely. Place the grommets back in the metal receivers and press down making sure each dowel pops into place.
Old 01-01-2021, 02:39 PM   #7
joekd
Drives: 2018 Camaro SS vert
Funny, I can get all of the ones on my 18 SS just fine using my cordless dewalt driver
Yes you need to have the perfect angle for the last one in the back but I have had it on and off several times, never an issue
joekd is offline   Reply With Quote
Old 01-01-2021, 04:09 PM   #8
Jaxcam02
Jaxcam02's Avatar
This was my technique before I dropped one of the screws into Narnia. I had to take the driver's wheel off and a bendable extended magnet to find it.
Old 01-01-2021, 04:46 PM   #9
az4783054
Drives: SWXXZL1
Either magnetize the tool or stuff a rag down beneath the air box. I lost fasteners and sockets in my Silverados and Corvettes until the obvious occurred to me.
"Joe" does a hilarious impression of a slinky toy on stairs.
az4783054 is offline   Reply With Quote
Old 01-01-2021, 04:59 PM   #10
joekd
Actually I use the drill to loosen them until they are sticking up then pull off the whole cover and fully remove once off the car
Old 01-01-2021, 04:59 PM   #11
Jaxcam02
Jaxcam02's Avatar
I just went to the rotofab so I don't have to deal with it anymore lol.
Old 01-01-2021, 05:45 PM   #12
az4783054
Drives: SWXXZL1
Good for you! Support our local businesses here in northern AZ.
Old 01-01-2021, 06:31 PM   #13
Mark R
Drives: 2018 ZL-1
You want to sell me a couple of airbox screws?
Old 01-02-2021, 07:58 AM   #14
Stephen12ZL1
Drives: '21 ZLE A10
try Fastenal...they seem to have everything
