Old 12-28-2020, 09:28 PM   #1
LTCamaro
Drives: 2016 Camaro
O2 sensor locations
Guys i need the distance from the manifold-converter flange to the 1st O2 sensors please. this is for an engine swap using camaro manifolds. if different on each side list them by driver and passenger please and thanks
LTCamaro is offline   Reply With Quote
Old 12-28-2020, 10:53 PM   #2
SS_1LE
Drives: 2020 SS 1LE
Both driver and passenger side are immediately after the manifold/cat flange. Literally about 2-3 inches probably form the flange
SS_1LE is offline   Reply With Quote
Old 12-28-2020, 11:06 PM   #3
LTCamaro
Drives: 2016 Camaro
yeah by some pictures i have looked at thats about right but wanted to see if someone had some cats laying around might could put a tape on them. Thanks though
Old 12-28-2020, 11:39 PM   #4
SS_1LE
Drives: 2020 SS 1LE
I just did headers, I can measure from the flange for you
Old 12-29-2020, 10:52 AM   #5
LTCamaro
Drives: 2016 Camaro
I would appreciate that very much.
Old 12-30-2020, 07:25 PM   #6
LTCamaro
Drives: 2016 Camaro
Im still needing this information please.
Old 12-31-2020, 08:01 AM   #7
JSH
JSH's Avatar
Drives: '20 ZLE
Sorry, I can't tell what you're asking. If you're going to cut a bung (8 total) into each exhaust pipe, the bung should be 3" or so from the flange but be careful to locate them such that they do not obstruct other work you will perform such as on spark plugs
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 12-31-2020, 08:07 AM   #8
cmitchell17
Drives: 17 2SS, 8L90, Cam, Heads, E85
Originally Posted by 6spdhyperblue View Post
Both sides appear to be similar
If you still have those out, can you measure the length of each connector and the diameter? (Or just circumferences?)
cmitchell17 is offline   Reply With Quote
Old 12-31-2020, 06:33 PM   #9
LTCamaro
Drives: 2016 Camaro
4 bolt flange at converter to 1st o2 sensor
Old 01-02-2021, 11:16 AM   #10
LTCamaro
Drives: 2016 Camaro
Anyone?
