![]() Drives: 2016 Camaro 2SS Join Date: Nov 2016
Anybody got a starter diy?
Out of warranty and I'm sure I need a starter.
Sent from my iPhone using Tapatalk |
![]() Drives: 2023 LT1 A10 Join Date: May 2017
I just did mine. I've heard a few different ways to do it.
After messing around with it for a while I decided to take off the exhaust piece under it. Had to heat the nuts up a little on the exhaust. After that it was basically just shimmying the heat shield out and then the starter. It's tight in there.
2023 LT1, A10, NPP, Tech, Recaros, BVFKQ6 (Ordered 6/24, TPW 7/25, Built 8/1, Picked Up 10/3)
Past: 2017 1SS A8, 1998 SS M6, 1995 Z28 M6 |
Lethal Camaro
Drives: 16 2SS, 71 Std, Suburban RTS Join Date: Jun 2013
removing the cat is the best way to go and makes it much easier to access. If you have LT's, removing the headers also make it a lot easier.
