Drives: Fast if no one's looking Join Date: Aug 2019
Electronic Parking Brakes = test of your sanity
I needed to refill the gas in my snowblower this morning. My gas can is on a shelf in front of where the Camaro is parked and my snowblower is on the other side of the garage. So I just thought I’d throw it in neural, release the parking brake, and just lean back on the B-pillar to push the car back about the foot I needed to to get to my gas can - like you can do with every single manual transmission since the car was invented.
Alas, it was not to be. I had to go back in the house, get my fob, and put it into acc mode to release the parking brake. I really wanted to shoot the engineer who said “yeah, electronic parking brakes are a great idea on a MANUAL transmission” How the hell do you release it if the battery dies while it’s set????? I wasn’t keen on it to begin with but now that I know first hand what a limitation it is it’s really irritating! |
WHEELIEFEST 22 ~ 8/14/21
Drives: 18 HW, 16 Vette, 09 G8 GT, 02 Formu Join Date: Jan 2011
I DESPISE the electronic parking brake!!
24 Panther 3LT RS Camaro 6SPD
21 Cadillac CT5 Sport 18 Hot Wheels 2SS convertible 16 Torch Red Corvette 2LT 7SPD 10 Inferno Orange Camaro 2SS 426 HP LS3 "MAIDEN" (TOTALED!) 09 Stryker Blue G8 GT w/sport/prem/sunroof 02 Firebird Formula LS1 HURST 6SPD(1st new car) |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
To play devil's advocate, it does save interior space(which this car desperately needs), and if you are low on battery, I would think any competent professional towing services would have a way to boost your battery.
And while I know you can use the buttons on the remote to unlock your car, I would think that most of the time, people would have the fob on them with the door button, which also makes this a non-issue for the most part. My complaint with the electronic brake on the Camaro is rather how slow it is. The Mazda6 I drive now has a pretty quick one, maybe twice as fast as the one on the Camaro. Sent from toaster or something
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
![]() ![]() Drives: 2015commemorative vert 2SS Join Date: Oct 2013
I agree they are way over engineered. I hate to say, the last 4 cars that were manuals, I never used the parking brake the entire time owned them. Just left it in gear when parked.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded 2015 commemorative vert 2ss |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
Idk Petrol Head, but I like the electronic brake and have finally gotten used to it being in the 6gen. It makes for a cleaner appearance in the interior and definitely takes up less room around or on the center console. I guess if the battery dies then it can’t be operational. Maybe we can get one of our members to test it out and report back so everyone will know if the brake will release without battery power!
#6 | |
Also, if your battery is dead with a manual you can push it (so long as you’re not facing up hill) in neutral up to a few miles an hour, hop in, push in the clutch and put it into first, then pop the clutch and the car will start. No battery or competent professional towing service needed! |
#7 |
There should be a manual override release handle somewhere like in the trunk or something
As far as space is concerned, there are manual parking brake handles in cars that are very tiny and take up little space. They could have fit one on the console |
#8 | |
![]() Reading through this section of the service manual, I did learn two interesting and potentially useful things, however: - first, the parking brake can be used while in motion, just like an old school mechanical lever, by pulling up the button and holding it in that position (the EPB will be applied as long as the switch is kept active and is released when the button is released, unless the car stops completely, in which case it remains applied); and - second, the tensioner cable can be released completely by holding the brake pedal down AND pressing and holding the parking brake button for 10 seconds with the ignition on and the engine off (pressing the start button first without the clutch/brake pedal pressed), in case the cable needs to be replaced
#9 |
So refreshing to get into my wife’s Nissan 370Z (Nismo), with the old school ebrake. The design just wasn’t broken...
#10 | |
![]() Drives: Camaro Join Date: Dec 2016
Thanks for sharing that, I was I always curious if they'd work in motion like a manual e-brake can. |
#11 | |
Not only was the design never broken, a manual transmission requires a completely mechanical parking brake for the reasons I stated earlier. |
#12 |
Agreed, which is why it’s refreshing to drive hers from time to time. Love the old school.
#SaveTheManuals
#13 | |
And yes, I know the old pull start trick, but most remotely modern cars warn you about not doing it as it can damage the emission systems in the Owner's Manual, and I don't think I will bring my Camaro to areas where I can't even call for any emergency service. Now if this is in something like a Wrangler or Bronco, then I get the complaint more as these are very much capable of traveling to middle of nowhere. Personally I am just indifferent about the design. Just takes getting used to. Sent from toaster or something
Current:
#14 | |
I’ve pushed manual cars around lots of times without starting them when you just need to move them a few feet. No need to start them just for a few feet. Or even back them out into the driveway to wash them. Clutch popping a car does not affect the emission system any differently that the starter motor. It’s just like starting it with the starter motor, only in this case the transmission is turning the flywheel, not the starter motor. But they are both doing the exact same thing. And even if I am in the best neighborhood in the world, why should I wait for a tow truck or a battery jump when I can just start the car myself anyways? That’s one of the reasons to own a manual. Last edited by Petrol Head; 12-26-2020 at 09:49 PM. |
