Old 12-24-2020, 12:16 PM   #1
badass_lt1
badass_lt1's Avatar
Drives: 2016 Camaro SS 6MT
Fuse 51 Exhaust Keeps Blowing
Hi, per the title everytime I put in a new fuse to control the NPP valves (Fuse 51) it works for a bit until I pass 2k RPM's and then it blows. Any ideas on how to fix this? Thanks!
'16 Camaro SS 6MT
badass_lt1 is offline   Reply With Quote
Old 12-24-2020, 04:16 PM   #2
Warrior102
USCG Retired (MKC)
Warrior102's Avatar
Drives: 2018 2SS 1LE Black
I would start with unplugging the actuators and see if the problem continues (wiring harness/BCM), if it's OK plug them back in one at a time and test again.
Warrior102 is offline   Reply With Quote
Old 12-24-2020, 04:46 PM   #3
Paintslinger16
Two Lane Blacktop
Paintslinger16's Avatar
Drives: '18 Camaro 2SS
My guess right along the lines of @warrior102 is one or both are stuck. Once it’s energized that circuit is trying to close or open and since it can’t, it overheats and then pops the fuse
i would swap neighbors before i swapped exhaust
Paintslinger16 is offline   Reply With Quote
Old 12-31-2020, 11:42 PM   #4
badass_lt1
badass_lt1's Avatar
thank i have a borla catback coming in and will have my muffler shop check out the actuators!
