Old 12-23-2020, 12:30 AM   #1
Whipplecamaro
Whipplecamaro's Avatar
Drives: Camaro 2ss
3.5” pulley whipple
Was wondering if guys were swapping the 3.65” pulley with the whipple out for the 3.5” pulley.. or even the 3.375.
im not looking for tons more power. More of the hellcat whine lol. Doing a big gulp roto fab intake as well, and do 93 octane. If i do the intake and octane it needs a tune so best bang for buck is tuning with the pulley at the same time. Selling a house and having this covid stuff isnt the best idea for spending tons atm. Dont want ripping out internals and forging and going the whole way on it making the blower scream. happy with power level now. Ive been reading some guys have belt slip or your running out of fuel. Just want to know if you could get away with a 3.5” , 3.375 safely.
Whipplecamaro is offline   Reply With Quote
Old 12-23-2020, 01:27 AM   #2
sicpuppy
Drives: White 2016 Camaro 2ss/blue stripes
With the new air intake and you will hear more of a whine.
I just returned my Hellcat and the whine is intoxicating.
sicpuppy is offline   Reply With Quote
Old 12-23-2020, 02:57 AM   #3
ex-SS-ve
ex-SS-ve's Avatar
Went with the 3.250 the whine is definitely louder just cruising. Gets really loud under wot.
ex-SS-ve is offline   Reply With Quote
Old 12-23-2020, 03:01 AM   #4
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
You can do the 3.5” pulley without an issue on 93 octane. No way you’re getting belt slip on the 10-rib system unless you have the wrong size belt installed. I’d recommend at least a 95mm throttle body be installed at the same time to go with the new intake too.
Old 12-23-2020, 10:32 AM   #5
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I am running a 3.375 with Big gulp on E50 but I have a full fuel system. I can hear the supercharger quite a bit now. The Big Gulp made the biggest difference because I had the regular RF intake prior with the same pulley. You will likely need LT4 fuel system to run a 3.375 and more possibly more octane then 93. The 3.5 pulley and big gulp will put you right at the edge of the fuel systems capability on 93.
Old 12-23-2020, 03:38 PM   #6
Sledgehammer70
Lethal Camaro
Sledgehammer70's Avatar
Drives: 16 2SS, 71 Std, Suburban RTS
Currently running a 2.785 upper and a 9.1 lower. Spinning this monster to the moon. The noises it makes are insane.
Sledgehammer70 is offline   Reply With Quote
Old 12-23-2020, 03:55 PM   #7
Joshinator99
Moderator
The OP is not going to be doing that on a stock bottom end and stock LT1 fueling my friend. Well, if he does, he’ll only be doing it for one short pull.
Old 12-26-2020, 10:15 PM   #8
Whipplecamaro
Drives: Camaro 2ss
Awesome thanks guys. So cai with 93, and 3.5” pulley with stock fuel stock system and internals should be fine?
Old 12-28-2020, 10:39 AM   #9
Dagstar
Dagstar's Avatar
Drives: 2016 Camaro SS
If you go with the Big Gulp you'll probably need a reducer to fit the stock TB. And I think you'll be negating the purpose of a smaller pulley without upgrading your fuel system to take advantage of it, but wiser minds will reply.
2016 Gloss Black Camaro 1SS, A8, MRC, 6-Piston BBK
Whipple, LT4 fueling, AlkyControl, Kooks, Borla, Roto Fab, Mightymouse, aFe, Apex, C7 Carbon, etc...
Dagstar is offline   Reply With Quote
