Obsessed
Drives: 2016 Hyper Blue 2SS RS Join Date: Jun 2011
5th Gen tire sizes
Any problems in using 5th Gen tire sizes (245/45-20 and 275/40-20) on a 6th Gen? Tire height issue with speedo?
I don't particularly like the harsher ride on the lower profile tires. Thanks for any help. Jim
2016 Hyper Blue 2SS |
I'm no longer on the stock SS sizes, so can't physically check it for you, but that setup is 1" taller overall and the fronts might not fit under the strut perch (you need to check the available space), plus your speedo will be 3.6% off.
Wheel speed sensors will read 60 mph when you're actually doing 62-62.5 mph, but since GM, like everyone else, adjusts the displayed speed upwards to compensate for inaccuracies, this is not a huge deal IMO, your display will actually be closer to reality. You just have to remember there is no longer any "protection buffer" in case you should speed, not that anyone here would ever exceed the posted speed limits (right? ).Other than these two aspects, it should just work, the front/rear ratio remains almost identical, i.e. your rake won't change adversely, and in fact, the extra sidewall will help fill the wheel wells a bit better. You can check and experiment with various configurations at www.tiresize.com and www.wheel-size.com yourself if you want to fine tune your selections.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
That's a significantly taller tire than stock. I personally wouldn't run it for these reasons:
I'm surprised to you're finding the stock setup harsh. I have a 1SS with the base suspension (ie. non-MRC) and find it to be comfortable and well damped. Harsh is not a word I'd use to describe it, but opinions vary!
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
![]() Drives: 2018 ZLE Join Date: Jul 2014
I cant fit a 275/40 on my ZL1 as it touches the fender line resting. Driving I see even less good
#5 | |
Obsessed
It might be the Nitto Motivos the previous owner put on, they suck in the rain, or at least lose their grip easier than I would like.
