![]() Drives: 2021 LT1 Join Date: Aug 2020
Do you 1LE guys use smaller wheels for street driving?
Tried searching but this isn't easy to find:
I'm curious - do you guys that track your 1LE run a smaller set of wheels and save the stock set for the track? I know you have to Pay to Play, but the cost of the stock tires makes me think it would make some sense to run them on the track when the handling differences would be more apparent. |
Drives: 2018 Camaro SS1 1LE Join Date: Feb 2017
I haven't tracked my 1LE, yet, but if I decide to the plan is to buy another set of 1LE wheels and put track tires on them.
I'm running street tires now, that just makes more sense given the OEM tires aren't worth much unless it's warm and dry. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Oct 2011
The car easily overpowers smaller tires IME. Whether it's acceleration with mustang-sized tires or cornering with it's weight. You can go down a little, but then you are still close to the stock size and still expensive. If anything, you want the smaller wheel diameter for the track.
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
#4 | |
![]() Drives: 2012 GMC Sierra, 2018 Camaro SS 1LE Join Date: May 2016
What To Do About Daily Wheels / Tires with a SS 1LE
#5 | |
![]() Drives: 2018 SS 1LE Hyperblue Join Date: Jul 2017
I did. I actually bought a set of all seasons and 19x10s for DD duty before the car arrived. I live in the Pacific Northwest and we see a lot of rain so all seasons were safer than the stock goodyears. The stock wheels certainly grip better and have better feel, but all seasons make a lot more sense epecially when you're not looking to drive above 8/10ths on public roads. Also it allows you to run a square setup so that you can rotate the tires and get much better life out of them. |
#6 | |
![]() Drives: 18 Ford Raptor, 21 2SS 1LE M6 Join Date: Dec 2020
#7 |
![]() ![]() Drives: 2021 2SS 1LE Join Date: Aug 2020
I bought Apex ARC-8s 19x10 ET20 square for daily use and put Conti ECS 285/35 on them. This way I can rotate them for better wear and use them as a rain or "rain likely" track tire. This should work OK through the winter as it doesn't get overly cold in NC and I've heard the Conti's don't tend to get as slippery as other summer tires when the temp dips below 45. Doesn't save much money vs the Supercar 3s, but increases versatility and the DD safety factor. They can still handle full throttle acceleration for daily fun.
The OEM wheels will keep the Supercar 3s and be used for dry track only where they excel. |
#8 |
![]() Drives: 2018 1SS 1LE Join Date: Dec 2012
Going to a 19” wheel could cut rotating mass by a large amount. I’m excited to get my 19” apex setup and feel the difference with the slight gearing advantage and weight loss.
#9 |
![]() Drives: 2019 1ss 1le, blue wrap Join Date: Aug 2017
my stockers are only for the track. For my daily driving, I went with a 275/35-20 Continental DWS06 square on a the MRR M017 1le replicas. I did want to get a OE second set, but they are expensive, and take offs seemed gone as soon as they were posted. The MRR wheels are acceptable, i don't regret getting them.
#10 |
![]() ![]() Drives: 2018 Camaro SS 1LE Join Date: Jul 2018
Putting smaller wheels on a car? Definitely not.
#11 |
![]() Drives: 2017 Camaro 1LE Hyper Blue Join Date: Apr 2017
I have 18x9 with 275/40/18 General All Season tires all around for winter. I use the stock tires and wheels April through November. My car is outside so i can't just let it sit on the Goodyears.
#12 |
My '20 came with 19s and I can't think of a good reason to go smaller
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO. 15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR. 100 octane: 1045hp/1055tq. 100 octane + Alky MAF Meth (1) 10+: |
#13 |
Pretty sure they’re referring to the width lol. I can see it up north if you need some better all season tires, since they don’t really make them in these sizes.
2020 ZLE Roto-Fab dry
2018 Camaro 2SS 1LE - 2" TSP catless headers, Pray Ported stock IM/TB, Rotofab dry, DSX FF kit, dyno tuned by Pray. SOLD |
#14 |
I think we've got both going here because I see, "Going to a 19” wheel could..."
2020 ZL1LE A10.
