![]() Drives: On Hiatus Join Date: Apr 2020
Terrible Headlights
I don't drive the Camaro much in the dark, but when i do I can't see shit. The projector cut off is non-existent and anything below that barely lights up the road. I've done multiple retrofits before I don't want to go down that road again with this car. I can't justify $500+ worth of projectors for the off chance i'm driving at night. I live in a very rural area with tones of wildlife and the stock lights barely give me any warning.
Has anyone swapped in aftermarket bulbs and noticed an improvement? I don't want anything super blue in the 8000k range, just looking for better performance. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '18 1SS 1LE Join Date: Sep 2017
Just check and see if they are aimed correctly.
'18 1SS 1LE Black, PDR
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
Yeah, my car has excellent lights. In fact maybe too good, I get flashed more often than I'd like for high beams when I don't even have them on. I think this is normal for LED projectors and the more blue light they produce, many folks hate them.
This car has outstanding HID headlights and you seem to be the first or at least one of the first to mention visibility issues in the dark. Have your HID bulbs and/or your eyes checked. If you're still running the originals in your 2017, they may be close to end of life by now.
They are plenty high, the issue isn’t distance, it’s the visibility below the cutoff line.
Being flashed by other vehicles doesn’t mean your headlights are bright, it just means they are aimed incorrectly. The brightness level is just awful and its not a surprise that chev cheaped out on HIDs. Not all projectors are equal, I’ve had Morimoto Bixenons swapped in before and they are far superior. I might try different bulbs and if that doesn’t work I may look into retrofitting again.
#6 | |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 17 SS 1LE Join Date: Dec 2015
The OEM bulbs are about as good as you can get for output.. Phillips 4300k. If you want more light use a higher power ballast or change the projector
#8 | |
![]() Mine has a clear cut off, and good forward road illumination, and nice side of the road as well. Of all the shortcomings of these cars, headlamp brightness was not on my list. I guess it depends on what you are use to using previously. I had a C6 and the only thing missing in this department is separate functional driving/fog lamps on the Camaro. I enjoy seeing where I'm going at night, but don't have a problem with the Camaro lighting.
#9 | |
![]() Drives: 2019 SS1LE Join Date: Feb 2020
These lights are as good or better than any I have had, including aftermarket and my new suburban Trust me ,these guys don’t give you much advance warning. |
#10 |
Previous vehicles had Acura 4TL-R and the FX-R 3.0 bixenon projectors with the same Phillips bulbs in the Camaro. Maybe I’m just used to a brighter and sharper beam than what’s stock in the HID Camaro. I may look into the Bi-LED projector from Morimoto, maybe it will fit into the stock headlight housing.
#11 | |
#12 |
It's all what you're used to. Hope you still like the Camaro!
Straightaways are for fast cars...Turns are for fast drivers
#13 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
19+ Camaros all have LED headlights, just saying. They are different from the 16~18 SS, which uses HID headlights.
I think they are fine, though probably not the best headlights I have ever had.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
#14 |
