Old 12-17-2020, 09:04 AM   #1
LT4 650
LT4 650's Avatar
Drives: 2018 ZL1 1LE M6
Stage 1 Build question
So I am starting to decide on what I want to do for what I am calling my "Stage 1" Build. I already have a Roto-Fab CAI and I have read through many threads and I have done some research from a couple of (according to Camaro 6 and others) reputable builders.
Below are examples of what two different top builders are calling stage 1. I know I could do other things for my Stage 1 decision but I am focusing on one of these first and then headers for stage 2:
1) Stage 1 - CAI, Upper pulley (2.3), Ported throttle body, Gates HD green belt, Catch Can & Tune
2) Stage 1 - CAI, ATI balancer, Lower pulley, GM Crankshaft bolt, Gates HD green belt, Catch can & Tune
Thoughts on if either is better and why according to your experience. Thanks
2018 ZLE - M6, Nightfall Gray
GM previously owned:
2014 SS M6
2014 ZL1 M6
2019 ZL1 M6
2016 Z06 M6
LT4 650 is offline   Reply With Quote
Old 12-17-2020, 09:14 AM   #2
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Flex sensor and E85 tune would be my stage 1 mod. Then CAI and Headers. Pulley would be last. The LT4 supercharger just hammers the tires with torque when you pulley down. Plenty of power to be made on stock boost with other mods and it will be more efficient.
Old 12-17-2020, 10:27 AM   #3
Z OH 6
Drives: 2024 CT5-V Blackwing
I agree flex sensor and E85 and tune, too easy to make good power if you have E85 available.
Old 01-22-2021, 01:08 PM   #4
LT4 650
LT4 650's Avatar
Thanks for the response but E85 is not really available (one station and it is far)...I do have access to 100 octane but it is $8.29 a gallon. Otherwise we have only crappy 91 octane here in AZ.
So to my original post if I want to start with pulley and headers...which would be the best route? UPPER or LOWER pulley???
2014 SS M6
2014 ZL1 M6
2019 ZL1 M6
2016 Z06 M6
Old 01-22-2021, 05:18 PM   #5
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Doing the lower means it is less likely to see belt slip vs doing a smaller upper pulley. Do a minimum 95mm throttle body if you’re going down this road (along with CAI, headers, and pulley). If you don't have E85, or even 93, I'd plan on a splash of Boostane with every fillup to get your octane number decent.
Old 01-23-2021, 12:22 AM   #6
Markoz28
Drives: 18 ZL1 nightfall grey A10
I agree with previous about boostane. Put 4oz for every fill up of 91. It should raise octane to 94
Markoz28 is offline   Reply With Quote
Old 01-23-2021, 12:37 AM   #7
dbs1
Drives: 2017 ZL1
Where in AZ r u located? E85 available at I10/Elliot and Higley/Williams field.
And it is for sure the quickest, easiest phase 1.
dbs1 is offline   Reply With Quote
