Old 12-15-2020, 09:29 PM   #1
Heatseeker8
Drives: 2018 Camaro 2SS Hyper Blue
Msd intake see pics
Do you know if this is normal on msd intake?
Looks like there is little pieces of plastic missing
See pics of runners
Thanks for input in advance
Heatseeker8 is offline   Reply With Quote
Old 12-15-2020, 11:00 PM   #2
Puddin
Not sure if that's normal but I will say the quality control for these manifolds is atrocious. I honestly wish there was a manifold that worked as good but was better put together.
Old 12-16-2020, 06:35 AM   #3
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 12-16-2020, 06:40 AM   #4
Puddin
Originally Posted by BlackbeastSS2 View Post
There is a manifold just as good and might even be better. It’s called the LT2 Manifold and way cheaper.
https://gwatneyperformance.com/produ...old-126977114/
Not for a cammed or stroker motor. Even Pray said if your doing a cam the MSD is your best bet unless you cut your hood then the High Ram is king.
Old 12-16-2020, 06:52 AM   #5
BlackbeastSS2
Old 12-16-2020, 07:13 AM   #6
Puddin
Your absolutely right about the price. I think the MSD should be around 750 to 800 at the most. Another reason against the lt2 for me at least is I run a 103 and if you port the lt2 to match the 103 the manifold gets way too thin in the throat for boost.
Old 12-16-2020, 07:15 AM   #7
Heatseeker8
Thanks for replying on the lt2 debate. I went back and forth many times on the lt2 vs msd
Gpi/pray has said porting the msd is 10 plus rwhp so that’s why I went this route.
The box stock msd is same peak hp to a PORTED lt2 according to the video.
So 798 for ported lt2 with port matching lt5 Tb vs $885 msd( on sale) . I do believe the msd will bring more resale down the road also when jumping to boost world .
Now
Anyone tell me if this is normal quality of msd?
Old 12-16-2020, 07:16 AM   #8
Puddin
Heatseeker I'd contact MSD and see what they say or maybe get them to swap you out with a different one.
Old 12-16-2020, 07:23 AM   #9
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Id' call that a very poor porting job, you think you're doing that to smooth air flow and then you just make it worse. Ya I'd send that thing back to MSD.
Old 12-16-2020, 07:34 AM   #10
6spdhyperblue
Drives: 2SS 1LE
That’s just the way they are
Old 12-16-2020, 07:43 AM   #11
BlackbeastSS2
Old 12-16-2020, 08:59 AM   #12
rallenrpd
Is a tune required after the install of an MSD Ported Intake? Lets say I already have a ported TB by Soler.
Thanks
rallenrpd is offline   Reply With Quote
Old 12-16-2020, 09:05 AM   #13
Heatseeker8
I ran a 103 on the high Ram and was not totally sold on it +/- . This is one of the reason I picked up the 95mm for current build. The LT2 when ported for the 103 becomes weak in the neck and more suited for the 95mm. That’s the main reason I selected the 95 mm, plus u shouldn’t use the 103 on a ported LT2 on boosted applications, simply to thin after porting.
I added a pic just to compare, pic is after porting.
https://youtu.be/rZSprqJHA9I
Man, talk about hijack
Great you love your combo. I see it in your thread you made
I’m here not to debate your setup or want pics of your porting
Just trying to see from other members if my msd is delivered like others
Old 12-16-2020, 09:40 AM   #14
BlackbeastSS2
Sorry buddy it’s a forum. Had mine hijacked many times. Just doing input. I will note your name and reframe from future comments. Take care.
