Old 12-14-2020, 09:29 PM   #1
PeteSS2018
Drives: 2018 2SS Camaro
Fuel System Upgrade
I'm hoping one of the members here can advise on a few questions about upgrading my LT1 (supercharged) fuel system:
1. Is it best to just get high & low side pumps, injectors and any required fuel lines in one go?
2. Best place to buy these as a package/kit with all parts? (I'm in Australia and they're just not really available here)
3. Any particular issues that I need to think of to have LT4 system with whipple SC to avoid problems/future issues?
Thanks all
2018 2SS, Hyper Blue, Australian HSV delivered
2.9L Whipple 98RON tuned 650hp/850Nm
Elite Engineering E2 Catch Can
Eibach Prokit springs
Mamo LT1 Ported TB
PeteSS2018 is offline   Reply With Quote
Old 12-14-2020, 09:53 PM   #2
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Thanks all
1. Yes. Don’t forget the high pressure lines as they typically get replaced (not reused). And get a JMS voltage booster for the low side pump.
2. I ended up shopping around to get everything but DSX or Wildhammer might have it all.
3. Your tune needs to be adjusted to work with the LT4 fueling.
Old 12-14-2020, 10:55 PM   #3
GAOLDGUY
GAOLDGUY's Avatar
Drives: 2012 GMC Sierra, 2018 Camaro SS 1LE
Long Distance Fuel System Purchase
Thanks all
Being that you are in Australia I would consider dealing with someone like Jannetty Racing.
https://jannettyracing.com/
He provides a tremendous amount of advice on the forum but if you look at his work on facebook, he provides extensive tuning and dyno testing. If you read his fueling recommendations, it is clear that he has experience with the entire system and understands the limitations and ramifications of the fuel system at your level of modification. He can also remote tune. Give him a call and I think it would be money well spent.
By the way, I think it is totally cool that you are doing all that from Australia.
GAOLDGUY is offline   Reply With Quote
Old 12-15-2020, 12:43 AM   #4
Herold Motorsports
Herold Motorsports's Avatar
Drives: 2017 Chevrolet Camaro SS
We typically do LT4 pump/injectors first
Then cam
Then auxiliary system
Then in tank pump.
And if they still want more, port injection system at the end.
There’s also methanol.
Herold Motorsports is offline   Reply With Quote
Old 12-15-2020, 02:30 AM   #5
PeteSS2018
Cheers mate yes, I've been look at JRE's website and they seem to have the goods. Actually looking to probably get a 95mm TB and HPTuner and get them to send the hardware and then do the tune for me. Your advice is appreciated.
Mamo LT1 Ported TB
Old 12-15-2020, 09:04 AM   #6
JANNETTYRACING
JANNETTYRACING's Avatar
Thank you for your recommendation, much appreciated.
Hello Peter, and welcome,
I received your email and responded any questions please post them here for all to share.
This is the fuel system you will need.
https://jannettyracing.com/products/...2018-camaro-ss
www.jannettyracing.com
email tedj@jannettyracing.com
Old 12-15-2020, 02:54 PM   #7
PeteSS2018
Yes, thankyou Ted, received your email also so thanks. It looks like that is what I need, I appreciate the advice. Now to find a suitable workshop over here that can do the install. This will be my next 'project' for 2021.
Mamo LT1 Ported TB
Old 12-15-2020, 03:24 PM   #8
wnta1ss
Drives: 2017 Camaro 1SS
FIRST check with Whipple (maybe give serial number?) whether yours will clear an LT4 high pressure pump. I knew someone that bought one of the early Whipples for the LT1-powered Camaro back in early 2017 and theirs would not clear.
Old 12-16-2020, 04:20 AM   #9
PeteSS2018
I
Ah yes, good tip, thanks. I seem to remember hearing this mentioned once before, so thanks for reminding me! I'll contact Whipple, cheers
Mamo LT1 Ported TB
Old 12-24-2020, 02:02 PM   #10
Brianw36
SNSTRSS
Brianw36's Avatar
Drives: 2016 Camaro 2SS A8
Not trying to hijack this post. I was wondering if you have an lt4 in-tank pump along with the lt1 high side with a 38% cam fuel lobe, can adding lt4 injectors help? I've heard lt4 high side pump doesn't like 38% fuel lobe. Any help would be greatly appreciated.
2016 Black Camaro 2SS A8 NP
Brianw36 is offline   Reply With Quote
Old 05-08-2021, 09:56 PM   #11
Lmndaid
Lmndaid's Avatar
Drives: 2020 Chevy Camaro SS
Then cam
Then in tank pump.
Why not do port injection from the get go? I know this is an old post but going around in circles as to what to do here. My goal would be 800-900 whp.
Lmndaid is offline   Reply With Quote
