Old 12-14-2020, 08:17 PM   #1
CamaroJim56
Obsessed
CamaroJim56's Avatar
Drives: 2016 Hyper Blue 2SS RS
2016 SS Dependability
5th Gen owner here, 13 2SS/RS
I want to make the move to a used 6th Gen, someone has a nice low mileage 16 available, but I am always nervous about a 1st year of a major model change.
So, were there any real issues anyone knows of that was present in a lot of 16s?
I appreciate any help.
Thanks.
Jim
2016 Hyper Blue 2SS
CamaroJim56 is offline   Reply With Quote
Old 12-14-2020, 08:29 PM   #2
STReddy1999
STReddy1999's Avatar
Drives: 2020 Camaro 2SS 1LE
My 2016 2SS had no issues, bought it used from original owner at 26,000 miles and it was driven so lightly it still had the original tires with plenty of life left. I proceeded to finish what was left of them in 5000 miles of spirited driving, never had any issues. Some automatics had transmission shuddering issues, but they have mostly been fixed by now.
2020 Camaro 2SS 1LE
2018 Mercedes-AMG CLA45 - Sold
2016 Camaro 2SS - Sold
2014 Camaro RS - Sold
STReddy1999 is offline   Reply With Quote
Old 12-14-2020, 10:59 PM   #3
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
I had a 2016 1SS for 9600 miles.
1. A8 shudder (minor), probably would have been fixed permanently with the latest fluid change.
2. Anti lock brakes engaged under normal light braking, stop and go traffic. Shut car off and restarted. Problem solved.
3. Had NPP rattle, pulled fuse and problem went away. Theres now a permanent fix, so no need to pull the fuse.
4. Had an intermittent cylinder misfire, probably a failing fuel injector, but didn’t keep car long enough to find out.
I know this sounds like a lot of issues, but the car ran awesome 99% of the time.There are TSB’s (technical service bulletins) to resolve all of these first and second year issues.
Old 12-14-2020, 11:27 PM   #4
enzia35
Drives: '16 Garnet Red 1SS
Starter overheat issues.
'16 Camaro 1SS
'18 Miata GT
Old 12-15-2020, 12:44 AM   #5
indyz
Drives: 2SS, CT-R, LC500
Diff issue (has a TSB I think)
A8 shudder, (fluid fix as per TSB)
Starter overheat may be exacerbated by battery not being charged regularly, for example, short drives or long periods of no driving. Read the manual about the voltage gauge.
indyz is offline   Reply With Quote
Old 12-15-2020, 05:19 AM   #6
L78toLT1
L78toLT1's Avatar
No issues in 26K miles even with fairly extensive mods and numerous track days. I must have gotten a good one; I'm still on the original battery and haven't experienced any starter issues even though I undoubtedly have quite a bit more engine bay heat that similar, non-modded cars.
Baby Blue
Old 12-15-2020, 07:00 AM   #7
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Jim, no issues when I bought my new 2016 2SS with the M6 transmission low option Camaro. You should be fine with the 2016 but you will probably miss your 5th gen if you get rid of it. The 6gen is smaller inside but looks better with the dash layout and seats. The handling is more nimble and the car weight is lighter which is a good thing. I sometimes miss my modded 2010 2SS but that quickly goes away when I drive the ZL1. May I suggest looking for a newer 2017 or 2018 and with a M6 6 speed unless you want the A8 auto. The manual makes it more fun to drive in my opinion but some people like an Auto trans. Either one you get will be a good choice in my opinion and if you are really set on the 2016 then you will enjoy a 6gen. Good luck!
Old 12-15-2020, 07:06 AM   #8
6spdhyperblue
Drives: 2SS 1LE
No issues
Old 12-15-2020, 08:28 AM   #9
akelly78
akelly78's Avatar
Drives: 2016 Red 2SS
At 43K miles and no issues
akelly78 is offline   Reply With Quote
Old 12-15-2020, 09:36 AM   #10
red_johnny
red_johnny's Avatar
Drives: 2016 Gray 2SS M6
Bought mine used. Had 6,000 miles on it. I now have over 18,000. No issues other than the slow crank to start. Even with that it has started every time and only happens after a lot of stops and go (short quick trips). Oh a small other issue, I have the stick and some times (especially on cold days) the idle revs up much higher and stays there for about 30 seconds. I want to get a Solar TB to fix this.
red_johnny is offline   Reply With Quote
Old 12-15-2020, 10:28 AM   #11
Puddin
1. Lost an oil pump which cost me a motor
2. Had to have the A8 shudder fixed
3. Ac temp sensors went out and had to be replaced
4. Slow crank due to starter location
Even with all the problems I did have I like the car so much that I've decided to keep it and modded it into a completely different car.
Old 12-15-2020, 11:13 AM   #12
BrianL
BrianL's Avatar
Drives: 2016 2SS, Red Hot, NPP, Nav, M6
20K trouble free enjoyable miles. Still on the original tires, but they are getting thin now and we live in a rainy climate, so I want to swap to AS when it's time. Only performance part I have installed is the Mamo V2 PTB, which I also like.
Had the differential groan first thing on a cold AM, and I changed the fluid myself as the dealer wouldn't unless they replicated it. That required them keeping it overnight, so I declined.
BrianL is offline   Reply With Quote
Old 12-15-2020, 11:44 AM   #13
KirkH
Full engine replacement at 52,000 miles: spun crankshaft bearing
Hard starting when hot problem.
Windshield wiper pump replaced.
HUD projector reset.
Old 12-15-2020, 11:51 AM   #14
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
had mine since new almost to 30k and paid off as of next year only problems i ever had was speaker and steering wheel cover replaced and battery replaced and my tensioner other than that car has been awesome
