Old 12-09-2020, 03:34 PM   #1
Sakudog
Sakudog's Avatar
Drives: 2019 ZL1 1LE A10
2017+ Tubular front bumper / crash bar, who makes one?
I have a good fabricator, but this job is so small, I'd like to see if anyone already makes one like Leftcoast does for the 5th gen...
Anybody know of a pre-made, tubular front bumper bar?
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Sakudog is offline   Reply With Quote
Old 12-10-2020, 06:40 PM   #2
Badmojo
aka BeastZL1
Badmojo's Avatar
The bumper bar weighs nothing. Tubular may actually weigh more.
2019 Camaro ZL1 1LE
Racing for ALS Youtube Link
Old 12-10-2020, 06:41 PM   #3
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
what are you trying to achieve? better or stronger?
Old 12-10-2020, 07:25 PM   #4
Sakudog
Sakudog's Avatar
I'm trying to accomplish what I just did, increase airflow. I guess you guys have never looked behind the fascia of a GT4 Camaro, but it looks "like this" with all the bullshit safety stuff out of the way, there is a TON of airflow there, to give more consistency and reliability on the track.
More air in, More air out. Will replace with a double bar chromoly bar created here locally by my fabricator, but for now this will have to do...
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Old 12-07-2024, 11:42 AM   #5
Geoff Darnell
Drives: 2020 camaro ss
Did you ever find a company that has a pre made tubular front end already fab all up???
Geoff Darnell is offline   Reply With Quote
Old 12-07-2024, 12:02 PM   #6
SWFLZL1
Drives: 2022 ZL1
Do some searching on here, a member makes them. I don’t want to say his name right now, because I think hes having trouble with the moderator’s. But a search will tell you all you need.
SWFLZL1 is offline   Reply With Quote
Old 12-09-2024, 01:40 PM   #7
Gonzo719
Drives: 2017 Camaro SS
I have the Cordes Performance bar if interested pmme
Gonzo719 is offline   Reply With Quote
Old 12-10-2024, 10:19 AM   #8
Evansa22
Evansa22's Avatar
Drives: 2018 HBM ZLE
Griffin-motorsports.com
Very nice product, I believe the weight is the same as stock.
Old 12-10-2024, 05:58 PM   #9
CamOnlyJabroni
CamOnlyJabroni's Avatar
Drives: 19’ ZL1 A10 / 16’ C7Z M7
I have a new Cordes unit I never installed
CamOnlyJabroni is offline   Reply With Quote
Old 12-16-2024, 07:10 PM   #10
airtroop01
Drives: 2018 Cadillac CTS-V
Does the Cordes bar still have the provision for the tow hook?
airtroop01 is offline   Reply With Quote
Old 12-16-2024, 08:09 PM   #11
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
No, it doesn’t.
Old 12-18-2024, 10:01 PM   #12
Patriot Motorsports USA
Patriot Motorsports USA's Avatar
Drives: 2021 ZLE, C5 Z06 6.0L Procharged
Cool
I have the Griffin bar that I modified to work with my combination. I am currently working on a new video that focuses on all the modifications I have done to date on my ZLE, to document the path I have taken to extract the most power I can with reliability on the stock platform. To date, on about 35% E mixed with pump 93 octane, 789whp and 807 lb/ft of torque with the stock cam, supercharger and heads!
I have focused on removing the OEM oil cooler, balancing the power of all 8 cylinders and making sure the MATs are in control by reversing the coolant flow.
In addition to removing BS heat from the engine, I am focusing on proper coolant management for the Supercharger by reversing the coolant flow and I have built the most efficient SCHX with the greatest volume on the market. It touts 100% coolant to airflow saturation with a triple bypass, the only one in the industry and will be available in 2025. Its all-aluminum design houses huge end-tanks to offer unrestricted flow and over 1.5 GALLON of coolant versus the OEM 16-ounces!!
Patriot Motorsports USA is offline   Reply With Quote
Old 01-13-2025, 10:24 PM   #13
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Yes sir... This is our signature product. Designed to create that "clear path" to the main HX, provide a "perch" for our oil cooler, includes a tow hook provision, air deflectors... and weights the same as OEM so no weight penalty.
Website in the signature if you want one
