Old 12-09-2020, 03:03 PM   #1
rastrophuck
Drives: Camaro 2SS convertible
Roof and windows issue
Hey! So, I´m unable to get my soft top up. I disconnected battery when it was down. DIC says to open and close driver window, done that 1million times, not working or the error message doesn´t go away.
All 4 window express up not working, express down working. When opening a door the window goes down a bit but when closing door not up.
I assume that the soft top doesn´t start its sequence because it is unable to roll down windows first.
I´ve tried disconnecting battery again - no luck. What should I do next to solve this problem?
rastrophuck is offline   Reply With Quote
Old 12-09-2020, 06:04 PM   #2
SHRFT
SHRFT's Avatar
Drives: 2017 Camaro 2ss 50 aniverssary vert
Unless there is a failure in the soft top mechanizm all I can think to do is check fuses and be sure no doors, hood or trunk lid is ajar.
SHRFT is offline   Reply With Quote
Old 12-09-2020, 06:29 PM   #3
Nitefall17
Drives: Camaro 1SS A8 Vert
Why did you disconnect the battery ???? Also there is sensor plug by the battery that might have got broke....that is for the top...
Other than that bad window motors or BCM.....
Nitefall17 is offline   Reply With Quote
Old 12-09-2020, 10:32 PM   #4
xandee
Drives: 2018 camaro 2LT
also, make sure that the partition in the trunk is properly snapped in place.
xandee is offline   Reply With Quote
Old 12-09-2020, 11:43 PM   #5
GroundhogSS
GroundhogSS's Avatar
There is a top position sensor behind the battery. If it comes loose or is disconnected, the top will not function. I knocked it off when I replaced the battery. It's the yellow plug in the picture.
Richard
Delivered: 08/15/2016
#TeamBeckyD
Old 01-19-2021, 09:31 PM   #6
Apxj
Drives: 2016 Camaro Rs Convertible
We’re you ever able to resolve this issue I’m experiencing the same thing?
Apxj is offline   Reply With Quote
Old 06-03-2021, 03:49 PM   #7
rastrophuck
No, sorry. Still no clue.
Old 06-03-2021, 04:19 PM   #8
MCgreek
Drives: 2014 Chevrolet camaro SS
No idea from here, check internet for a clue it will help
MCgreek is offline   Reply With Quote
Old 06-05-2021, 04:56 AM   #9
rastrophuck
I think I have a solution, but don't know how to manage this - the softtop must be in closed position to learn windows. But... the top is down and windows can't be indexed this way. So I have to somehow tell the car that softtop is in fully closed position.. any ideas?
Old 06-06-2021, 10:24 AM   #10
ember1205
Hot Camaro
ember1205's Avatar
Have you followed the operation instructions in the manual for Manual Operation of the top to get it fully closed?
Old 06-09-2021, 02:03 AM   #11
RJK
Drives: 2018 LT Convertible
My top on my 2018 wouldn't go up most the time, just started out of the blue after a year+ working fine, had to park the car, drive the car, wiggle the windows and it might work. Took it to the dealership about a month ago and found out its a software issue which they updated and its worked perfectly since.
RJK is offline   Reply With Quote
