12-02-2020, 06:45 PM | #1 |
Drives: 2017 Z06 Corvette Join Date: Nov 2020
Home Link Sun Visor
Does the 2020 2SS Camaro offer the home link sun visor?
12-02-2020, 08:53 PM | #2 |
Drives: Fast if no one's looking Join Date: Aug 2019
No. GM removed Homelink all together from the Camaro for 2019. It used to be in the overhead console above the rearview mirror and OnStar was on the rear view mirror. Then for 2019 they added the rear view camera rear view mirror and moved the OnStar buttons to where Homelink used to be.
I added an aftermarket Homelink kit. |
12-03-2020, 05:38 AM | #3 | |
12-03-2020, 06:44 AM | #4 | |
https://www.amazon.com/Homelink-60-H...6999270&sr=8-4 I installed it into the headliner between the sunroof and overhead console. I tapped into the 12 volt, headlamp, and ground wires in the overhead console (I don't remember which wires they were, I used a volt meter to find them), and put the module between the headliner and roof. You have to cut a small square through the headliner material to snap the buttons into the module. Looks like it came from the factory and works on every garage door, as I have a new one with the latest rolling code technology and my parents garage door opener is over 20 years old. |
12-03-2020, 07:21 AM | #5 |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
I considered installing the factory HomeLink setup on my 1SS, but ultimately just decided to velcro the remote to the small shelf under the steering wheel. It works well there, is completely hidden, and 'free'
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
12-03-2020, 07:28 AM | #6 |
Do you use your tilt wheel much? Looks like you'd crush your garage door opener if you moved your wheel. I use my tilt/telescope all the time getting in and out.
12-03-2020, 07:39 AM | #7 | |
I did the same just velcroing my garage door opener to my car, but instead of under the steering wheel, was a perfect space between the lights in the overhead unit with onstar. |
12-03-2020, 08:10 AM | #8 | |
With that said, I think I tested this out after installing it there and there's still clearance, but if you keep the steering wheel in a low position when driving you may not be able to reach the buttons there. If I think of it, I'll test this out and report back in case it's helpful to someone.
12-03-2020, 05:23 PM | #9 | |
12-04-2020, 10:19 PM | #10 |
No problem, glad I could help. I meant to take pictures and post a how-to but after I started working on it I forgot to get out my phone till I was all done lol
12-05-2020, 10:40 AM | #11 | |
I have to admit when I traded my 2017 2SS for my ZL1, I was annoyed with the loss of homelink. Can’t believe I wasn’t able to come up with the Velcro thing myself.
#SaveTheManuals
12-05-2020, 10:48 AM | #12 |
Drives: SWXXZL1 Join Date: Jul 2020
I applied a strip of heavy duty VELCRO to the back of my garage door opener and positioned it next to my knee on the carpet, just below the edge of the center console. The hooked VELCRO attaches to the carpet very securely.
"Joe" does a hilarious impression of a slinky toy on stairs.
12-07-2020, 11:24 AM | #13 |
